Bent a piston rod in my boom cylinder
   / Bent a piston rod in my boom cylinder #1
Frankman
Erie Co. PA
None yet
Was digging a ditch today and while busting a root I bent my hydro cylinder rod... Never would have thought it would have happened.... Still don't even understand how.. Anyway, does anyone have a source for a replacement piston rod that is reasonable? Part # is woods 37878. Maybe a local shop can find one for me, just figured you guys may know. Thanks.
Sorry almost forgot to tell you what i have! I have a Kubota 4610 and a woods BH9000 backhoe.
   / Bent a piston rod in my boom cylinder #3
Impressive wish i could help you with replacement parts. Its never a good felling knowing you just broke something not knowing how you did it
   / Bent a piston rod in my boom cylinder #4
Many hydraulic shops can make a replacement rod.
Bruce
   / Bent a piston rod in my boom cylinder #5
I am curious, would you describe what you were doing at the time? I am trying to imagine scenarios that would lead to that failure. Thanks and sorry, never fun to have a failure.
   / Bent a piston rod in my boom cylinder #7
OUCH man that's not good if you did that kinda damage to to the rod make sure you check fel arm's to make sure there not broke or cracked. sorry i know it sucks you got work to do and can't do it.
   / Bent a piston rod in my boom cylinder #8
In order to bend a shaft that is extended, you use another cyl/component and a mechanical advantage to apply more force.
What would happen if you bury the bucket 6 ft in the ground and tried to back the BH about 8 ft. the work port reliefs might go off, or the force might blow a hose or burst a fitting.
Mechanical forces are now involved by generating hyd force, and mechanical force. You might have a 10 to 1 relationship on the dipper to the boom.
   / Bent a piston rod in my boom cylinder #9
Yes! Figuring out how it happened is the way to keep it from happening again. One would expect a factory system to be suitably strong and tailored by hydraulic limits to be self protecting. Could there have been mechanical interference involved - either in the instant case or a prior one that bowed the rod?
larry
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
2016 Komatsu PC1250LC-8 Hydraulic Excavator (A50322)
2016 Komatsu...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
2018 Chevrolet Traverse LT SUV (A50324)
2018 Chevrolet...
2012 Ford F-150 (A50120)
2012 Ford F-150...
