Bent a piston rod in my boom cylinder
   / Bent a piston rod in my boom cylinder #1
Frankman
Erie Co. PA
None yet
Was digging a ditch today and while busting a root I bent my hydro cylinder rod... Never would have thought it would have happened.... Still don't even understand how.. Anyway, does anyone have a source for a replacement piston rod that is reasonable? Part # is woods 37878. Maybe a local shop can find one for me, just figured you guys may know. Thanks.
Sorry almost forgot to tell you what i have! I have a Kubota 4610 and a woods BH9000 backhoe.
   / Bent a piston rod in my boom cylinder #3
Impressive wish i could help you with replacement parts. Its never a good felling knowing you just broke something not knowing how you did it
   / Bent a piston rod in my boom cylinder #4
Many hydraulic shops can make a replacement rod.
Bruce
   / Bent a piston rod in my boom cylinder #5
I am curious, would you describe what you were doing at the time? I am trying to imagine scenarios that would lead to that failure. Thanks and sorry, never fun to have a failure.
   / Bent a piston rod in my boom cylinder #7
OUCH man that's not good if you did that kinda damage to to the rod make sure you check fel arm's to make sure there not broke or cracked. sorry i know it sucks you got work to do and can't do it.
   / Bent a piston rod in my boom cylinder #8
In order to bend a shaft that is extended, you use another cyl/component and a mechanical advantage to apply more force.
What would happen if you bury the bucket 6 ft in the ground and tried to back the BH about 8 ft. the work port reliefs might go off, or the force might blow a hose or burst a fitting.
Mechanical forces are now involved by generating hyd force, and mechanical force. You might have a 10 to 1 relationship on the dipper to the boom.
   / Bent a piston rod in my boom cylinder #9
Yes! Figuring out how it happened is the way to keep it from happening again. One would expect a factory system to be suitably strong and tailored by hydraulic limits to be self protecting. Could there have been mechanical interference involved - either in the instant case or a prior one that bowed the rod?
larry
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
White Metal Roof Panels (A55758)
White Metal Roof...
Fencing (A56859)
Fencing (A56859)
2012 HEIL (A58214)
2012 HEIL (A58214)
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
