Bending a 2" square tubing
   / Bending a 2" square tubing #21
If you don't have heat here's an idea that I used to bend some 1" square tube to follow a curved roof on my horse trailer using a chop saw and welding. Cut a slice every half inch over the needed radius. Bends real easy and keeps a very uniform radius. When at the desired bend then weld the slices and grind of the excess.
I need to bend a 2"x 3/16" square tubing about 15 deg. Other than cut and weld or take it somewhere, is there a way that I can do it at home? I have a 20 ton press but without using some kind of proper jig, I would probably end up distorting it too much.
Fishing for ideas.
Done dit it! I wanted a real small radius, which I don't think could have been done any other way.
Used a bandsaw to cut three sides, bend and weld as suggested. Piece of cake. Thanks for all the inputs.
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2016 LEEBOY 8510D ASPHALT PAVER (A60429)
2016 LEEBOY 8510D...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
1667 (A57192)
1667 (A57192)
CASE TR310 SKID STEER (A60429)
CASE TR310 SKID...
