Bending a 2" square tubing
/ Bending a 2" square tubing #1
NCMau
NC
MF 202/Ford 8N
I need to bend a 2"x 3/16" square tubing about 15 deg. Other than cut and weld or take it somewhere, is there a way that I can do it at home? I have a 20 ton press but without using some kind of proper jig, I would probably end up distorting it too much.
Fishing for ideas.
/ Bending a 2" square tubing #2
Do you have any heat you could apply to get it cherry red? If you want 15% exactly you'll need some kind of a jig. Even if you made the jig out of hard wood. Of course, you better have water near by when the hard wood starts burning.
Personally, I would cut out a triangle, leaving the back on, then bend and weld. But I don't have a good shop.
/ Bending a 2" square tubing #3
If you have some way to cap the ends, filling it with sand will prevent the walls fr collapsing when you bend it.
/ Bending a 2" square tubing #4
I have a pipe bender, i had to put an arch in a peice of square tubing as well. I took and put the 2inch square in the pipe bender on the 3 inch mandrel. I heated a large section of the tube and slowly used the bender to make my arch.
/ Bending a 2" square tubing #5
How big of a radius can the bend be made over.
IF you need a tight bend, I am afraid the only way would be to cut a triangle out. Otherwise, the sides will buckle and it will look like crap. Being only 3/16" thick, a slicer disk on a 4-1/2" grinder will make quick work out of it. Or if you have a bandsaw, set it to 7.5*, cut it all the way through, rotate one of the halves 180* and weld.
/ Bending a 2" square tubing #6
Here's a picture of what I was talking about.
Click on the picture to enlarge it.
That's a thought! What was the thickness of the tubing?
/ Bending a 2" square tubing #9
Mind if I ask what its for?
If welding is of no concern, I''d make ONE 7.5* cut and rotate peices 180* and re-weld. Instead of TWO 7.5* cuts 3/4 of the way around. Unless a smooth outside corner is the goal.
/ Bending a 2" square tubing #10
Got a torch? Heat a small wedge in the side where you want it to bend. First picture is of a beam, but same technique.
If you want a slow bend heat the heels of the box tube.
/ Bending a 2" square tubing #11
Here is a quick and dirty drawing of how to heat shrink square tube.
/ Bending a 2" square tubing #12
It was only like 1/4 wall. Nothing to heavy. I would bend a section roll it down the pipe bender and do another part of the arch. I had to make the arch follow the frame of an atv. It attached at the rear 2 inch receiver then follow the frame forward until it arched it up following the skid plate.
/ Bending a 2" square tubing #13
Buy me the dies for my bender and I will buy a section
of 2" and bend it and ship it for free! :D
/ Bending a 2" square tubing #14
That's a good idea! I should have thought of that:laughing:, but they don't make 2-inch square tube dies for my bender.:mad:
/ Bending a 2" square tubing #15
Oh but they make them for mine so were good to go!
CLICK HERE, Scroll to very bottom, make sure it is good
for you, send them the cash w/ my mail to addy and
I will bend you your part. Heck, I will even draw it up
w/ B"Bend-Tech" software too!
Guaranteed within .5*+/-
( I usually can get spot on...)
:D
/ Bending a 2" square tubing #16
Sorry to be the one to tell you this, but according to the website, Maximum Wall Thickness- .188". He wanted .250" wall.
/ Bending a 2" square tubing #18
I bet it would bend it anyway! If not, nothing a little time with a weed burner wouldn't help. ;)
/ Bending a 2" square tubing #19
In the original post, he mentioned 2" x 3/16 square tubing... so wouldn't that be .1875 ?
David from jax
/ Bending a 2" square tubing #20
My mistake, I thought later he mentioned using 1/4 wall. But that was nwngunner. Sorry! :eek:
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
TANK MANIFOLD (A58214)
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2021 CATERPILLAR 299D3XE SKID STEER (A60429)
2021 CATERPILLAR...
