Belt squealing on 2005 CK30 bad??
   / Belt squealing on 2005 CK30 bad?? #1
nvip9r
Mass
Kioti CK30
Just wondering if anyone could help me. Recently the alternator/fan belt started squealing upon first startup and does every so often on our 2005 CK30. I thought it might be loose so took a look at it and the alternator adjustment is all the way out and no more slack to tighten it. Is that normal? Is it going to cause a problem? The tractor only has like 160hrs. Should I put a new belt? Is it tough? Any idea on what belt is needed? Thanks for any help.
   / Belt squealing on 2005 CK30 bad?? #2
I've had my CK30hst for @5 years/350 hours and have adjusted the belt twice. The adjustment is out about half of it's full range. It definately sounds like you need a new belt but it shouldn't have stretched that much with only 160 hours. I can't imagine that the crank, alternator, and water pump pullys are out of line causing faster wear. Maybe a longer size was installed from the factory but it's time to shorten it up. Your water pump and alternator won't spin properly if the belt gets to lose.
I never measured my belt to know the size. It looks like a 4L width but no idea on length. If you take it off, an auto parts store can measure it and size you down a new one or call a Kioti dealer for a new belt. They are fairly simple to replace. Loosen up the alternator, slide the belt forward of the pullys, then out around the fan.
   / Belt squealing on 2005 CK30 bad?? #3
My CK30 has a big belt too. The adjustment is at the max tightness and I get the same startup slipping that you describe many times. I think it is because during startup the glow plugs are drawing so much juice that the alternator is really tugging on the belt. I would tighten the belt to fix this but I can't.
Since the slipping stops pretty quickly I just live with it. Adjust RPMS until it grabs and then no more slip the rest of the day.
   / Belt squealing on 2005 CK30 bad?? #4
Get a link belt then you can just take a link out to tighten the belt. They run smoother and quieter also.
   / Belt squealing on 2005 CK30 bad?? #5
My CK30 does a little squeal now and again at start up too. As it warms and few rpms it goes away. Hasn't done it enough for me to worry about, but if mine is the "long" belt, I'll shorten up on replacement.
2002 International 9200i Truck (A56435)
2002 International...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2009 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
