Belt replacement
/ Belt replacement #1
Tlysflys
Kubotta M5040
Last week my 2011/F was idling in when it stopped. It turns out the alternator belt broke and it overheated. Got a new belt at Napa ($22) and installed it. A two hours exercise of patience as the space is very tight. Everything worked out fine, but my suggestion is to replace the belt regularly. Mine has 500 hours and the belt showed cracks throughout. Could have ended in expensive engine damage which it apparently did not.
/ Belt replacement #2
If you would refer to your service chart in the operators manual you would see that the both Alt and AC belts are to be checked every 250 hours or 1 year. :ashamed:
/ Belt replacement
Live and learn!
/ Belt replacement #4
Good tip
Hope to own one of these in the future, used no doubt
/ Belt replacement
I misspoke, mine has 400 hours. Which of course reinforces the manual: check belt every 250 hours.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Case SV280B (A60462)
2016 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Truck (A61568)
2016 Globe Trailer...
2007 Reefer Trailer 53ft (A61165)
2007 Reefer...
New/Unused Brush Cutter for Excavator (A61166)
New/Unused Brush...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
