belt lubricants
   / belt lubricants #1
roger grady
Waldport, Oregon
Ford 1920
what have others found to be a good belt lube other than the very expensive small cans available at local hardware stores?
   / belt lubricants #2
I have never found a need for a belt lube. If the belt is tightened to proper tension and is slipping, it needs to be replaced. Belt dressing is a temporary solution at best.
   / belt lubricants #5
If you need a lube on the belt, you need a new belt. There are all kinds of products out there made to satisfy what someone thinks they need. Some of the old remedies such as soap actually speed up the demise of the belt. Proper tension and line-up keeps all surfaces in contact and they run cooler. If the belt runs hot, its slipping and life will be short. Belts and sheaves on manufactured products are an engineered solution.
Ron
   / belt lubricants #6
Welcome to TractorByNet!
I moved your thread to the Oil, Fuel, & Lubricants forum. :)
   / belt lubricants #7
Ron
I agree. I have owned a dozen tractors, 27 vehicles, and about 10 boats. Never needed belt lubricant.
Chris
   / belt lubricants #8
cat sells a yellow wax stick as a belt protectant but i do not believe they call it a lube...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
Utility Trailer (A52377)
Utility Trailer...
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
Pallet Fees (A50775)
