belt lubricants
   / belt lubricants #1
roger grady
Waldport, Oregon
Ford 1920
what have others found to be a good belt lube other than the very expensive small cans available at local hardware stores?
   / belt lubricants #2
I have never found a need for a belt lube. If the belt is tightened to proper tension and is slipping, it needs to be replaced. Belt dressing is a temporary solution at best.
   / belt lubricants #5
If you need a lube on the belt, you need a new belt. There are all kinds of products out there made to satisfy what someone thinks they need. Some of the old remedies such as soap actually speed up the demise of the belt. Proper tension and line-up keeps all surfaces in contact and they run cooler. If the belt runs hot, its slipping and life will be short. Belts and sheaves on manufactured products are an engineered solution.
Ron
   / belt lubricants #6
Welcome to TractorByNet!
I moved your thread to the Oil, Fuel, & Lubricants forum. :)
   / belt lubricants #7
Ron
I agree. I have owned a dozen tractors, 27 vehicles, and about 10 boats. Never needed belt lubricant.
Chris
   / belt lubricants #8
cat sells a yellow wax stick as a belt protectant but i do not believe they call it a lube...
2007 International 4300 Dump Truck (A51692)
2007 International...
2014 John Deere 244J (A47477)
2014 John Deere...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
