belly plate
/ belly plate #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
anyone built a skid plate for the under side of there tractor. i have a kubota
mx5100 bought new had ! hour on it ran a stump up thru the bottom, took
out radiator, fan, hoses, hood, oil filter, fan shroud & etc.
man what a mess. need to cover the entire bottom, any help on designing a
belly plate.
oh yea, did i mention i had [ ! } HOUR ON IT.
it`s in the shop now hope tpo get it back this week.
thanks,
candyman
/ belly plate #2
I have seen a B7500 with a belly pan made from 1/4 ? in. plate. It was flat with about six bolt on hangers. Can't recall how the oil plug access was handled.:)
It is possible. Just ask the mechanic's a few questions.:)
/ belly plate
who are the mechanic`s . ?
/ belly plate #5
I would include easy cleanout access in the design. If it fills up with a lot of chaff and grime it could become a very expensive firepit.
/ belly plate #7
I was wondering myself about stuff that people say, "if I can knock it down with the FEL the Bush Hog will take care of it" run over with their FEL then Wacke with the bush hog? What is the collective conscious opinion on running brush down for the bush hog? A protective skid sounds reasonable.
/ belly plate #9
I can tell you for a fact that the Ford 8N's with the belly exhaust didn't like to be ran through the brush.
/ belly plate #10
belly plate.
thanks,
candyman
Dam & here I thought they were indestructible.
/ belly plate #11
That is the reason for advice to GO SLOW and lower your FEL close to the ground with the bucket tilted up slightly when mowing in unknown territory. If you run into a stump it will ride up on it or stop you before you damage your tractor. I second the motion to make sure it has access to clean it as iti will for sure fill up with grass etc and may even cause you to overheat the crankcase oil as it will insulate it pretty good from proper air flowl.
/ belly plate
good thing for kubota insurance. was backing up & going very slow, happened so fast didn`even know anything was wrong until the white smoke.
walked the ground before i started into it can`t see everything. the shop told me of a customer who bought a new much bigger tractor with a cab had it for a short period of time ran a limb thru one of the windows ins. fixed it & two mths. later he came back with the same window busted again out by the same limb
, go figure.. stuff does happen.
all good suggestions, what groundcover said.
thanks
/ belly plate #13
, go figure..
Sounds like he needs to spend more time with his chainsaw than his tractor.
/ belly plate
i should have at least taken pix, but i do not know how to post them. just got
a call from the insurance company, still can`t talk as my jaw is still on the
floor,,,,,,,,,,,,,,,,,,,,,,,,,
cm
/ belly plate #16
I think some people should be required to film everything they do. I thing we have a new interesting member here
Ya like we never scratched the pickup riding through a field we shouldn't be driving in or picked up something heavy without using our legs:laughing:. Guys that warn about dangers have exeperienced them and survived or not:laughing:. Laughter is identification.:thumbsup:
/ belly plate
jb,
looks good. what is it & how did you mount it.
thx, cm
/ belly plate #20
jb looks good, I guess I will have to crawl under my tractor and have a look see as to what can be done. Thanks for the pictures.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
2012 International Prostar (A61306)
2012 International...
2025 DIGMASTER DM100 EXCAVATOR (A60430)
2025 DIGMASTER...
