Belly Pan for JD 110
   / Belly Pan for JD 110 #11
If you can, get the machine on a level spot and on a hard surface (concrete or asphalt) , get a floor jack and try to center it under the skid plate, jack it up so it is just resting on the underside of the skidplate, remove the mounting bolts, and SLOWLY lower the jack, the skidplate may slide if it is not balanced so be careful. Check the valve then reinstall the plate. Good luck....
D Reed, Tags is right on about the floor jack!! I have a flat furniture dolly that I put on the center head of the jack. Only other tip is to make sure to use a alignment punch thru the skid plate holes to help line up the bolt holes. I would put in by hand to make sure to get them started straight. It's easy to cross-thread them if you're not careful.
Good luck!!
   / Belly Pan for JD 110 #12
Its in my shop and I have floor jacks and a 10K auto hoist so I'm not worried about that part. I can't get the bolts loose. Frozen solid., been soaking in KROIL no for about 12 hours. the 6mm drive socket does not have what it takes to break the bolt free.
Any ideas?
Drew
   / Belly Pan for JD 110 #13
D Reed,
6mm, that sounds like something different than the skid plate bolt. Not sure, but I was thinking they were about 17 or 18mm heads. Or are you talking about the valve body?
   / Belly Pan for JD 110 #14
My skit plate has 6 counter sunk allen drive bolts. The bolts requires a 6mm allen drive to remove them. I'm guessing they are counter sunk so they are flush with the skid plate.
D
   / Belly Pan for JD 110 #15
D
OK, mine's different then. It just has regular hex head bolts. I did order it from the dealer, and put it on after my machine was delivered.
Might try an impact, if you want. Maybe a little heat as well, but I know it's not an easy area to get to, maybe just a handheld propane torch?
   / Belly Pan for JD 110 #16
That's different than what I have. I believe that the bolts are 14mm hex head or so on mine. Recessed allen head could create a situation for "seizing"; I'd guess.
I've seen allen wrench stubs with a socket drive. So, if you could get your hands on an impact driver...
AKfish
   / Belly Pan for JD 110 #17
I have raised and lowered big and very heavy belly pans successfully with a couple of cable come-a-longs. The advantages are that it is more stable and less likely to fall off, it is easy to slide on the cable and position it for installation, and one man is able to maneuver even a large and heavy pan.
If you have tried penetrating oil then about the only option is to heat it as hot as you can get it (red is nice) and then let it cool--the temper is lost. The expansion and retraction will pull it loose from the rust. Put new bolts in with "never seize."
Mike
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
40 Dry Van Enclosed Trailer (A57453)
40 Dry Van...
