radarfortractors
- Joined
- Jul 28, 2011
- Messages
- 5
- Tractor
- kubota bx2320
Any one know who makes the bolt on belly pan protector skid plate for the Deere 110 TLB ? Thanks for your help.
available ONLY at DEERE. Soon not available at all because Deere just discontinued the 110TLB tractor due to miniexcavators taking the lions share of the market. SO ORDER NOW OR FORGET IT.![]()
If you can, get the machine on a level spot and on a hard surface (concrete or asphalt) , get a floor jack and try to center it under the skid plate, jack it up so it is just resting on the underside of the skidplate, remove the mounting bolts, and SLOWLY lower the jack, the skidplate may slide if it is not balanced so be careful. Check the valve then reinstall the plate. Good luck....
My skit plate has 6 counter sunk allen drive bolts. The bolts requires a 6mm allen drive to remove them. I'm guessing they are counter sunk so they are flush with the skid plate.
D
