Mowing Belly mower
/ Belly mower #1
laen46
Is it possible to make an L2350 into a belly mower? If so, what would be needed?
/ Belly mower #2
Hey man anything is possible. First I'm guessing your tractor is a hydro. Next you need to figure out what type of deck you are supposed rc60-???, then you need to start hunting for your mounting hookup. You will need, 4 mounting brackets that mount to frame(most likely 4), you will need your 2 main hindging arms for both sides of the deck, next you will need your drive shaft(if you cannot find exact length always get longer( I can walk you through resizing and still having balanced straight shaft, you will need to find how the mower deck lifts, most seem to lift off of three point hitch, If this is your type- you will need to find a bracket that goes on the three point base and then the rod that connects it. I know it seems like a lot of work but it really isn't bad. I just converted my tractor and I have a feeling it was probably worse than this should be. You mainly need to ask yourself if this is worth the money and time. If it is no question than be prepared to spend about 1000 to 1500 maybe more it may depend on how much you do your self. any questions shoot me an email
/ Belly mower #3
i have a rc60-72h deck and all the brackets most brand new asking 650.00
/ Belly mower #4
For that, all said and done, I'd grab your mower mount it trouble-free, and mow away! :)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
PALLET OF DISCHARGE HOSES MISC SIZES (A68842)
PALLET OF...
2020 CATERPILLAR 320 GC EXCAVATOR (A65056)
2020 CATERPILLAR...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
