Mowing Belly mower
   / Belly mower #1
laen46
Is it possible to make an L2350 into a belly mower? If so, what would be needed?
   / Belly mower #2
Hey man anything is possible. First I'm guessing your tractor is a hydro. Next you need to figure out what type of deck you are supposed rc60-???, then you need to start hunting for your mounting hookup. You will need, 4 mounting brackets that mount to frame(most likely 4), you will need your 2 main hindging arms for both sides of the deck, next you will need your drive shaft(if you cannot find exact length always get longer( I can walk you through resizing and still having balanced straight shaft, you will need to find how the mower deck lifts, most seem to lift off of three point hitch, If this is your type- you will need to find a bracket that goes on the three point base and then the rod that connects it. I know it seems like a lot of work but it really isn't bad. I just converted my tractor and I have a feeling it was probably worse than this should be. You mainly need to ask yourself if this is worth the money and time. If it is no question than be prepared to spend about 1000 to 1500 maybe more it may depend on how much you do your self. any questions shoot me an email
   / Belly mower #3
i have a rc60-72h deck and all the brackets most brand new asking 650.00
   / Belly mower #4
For that, all said and done, I'd grab your mower mount it trouble-free, and mow away! :)
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
