belly mower to 3pt mower
   / belly mower to 3pt mower #11
The gearbox on your mmm is probably 1:1 (like my JD mmm). The RFM version using the same deck components is about 1:3. Have you looked into buying just the gear set? Change out the 1:1 and put in the 1:3. The gearbox housings look to be common, but I'm not sure about the Kubota mid-pto turn direction vs. the JD. . If not, I've seen a few complete gearboxes (used) on eBay.
Then you need the brackets and a drive shaft.
If you already have the mid to front pto kit (lets say for a snowblower), AND you have some fab skills, consider using that deck for a front offset mower. Its a cool wayto get under the pine trees without getting your face slapped by sap filled braches. You could make use of the FEL frame to do a QA rig, or just push it from a Rube Goldberg forward linkage.
   / belly mower to 3pt mower #12
But the input to the gearbox is also facing in the wrong direction.
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
2013 International Derrick Digger Truck (A55973)
2013 International...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
