belly mower to 3pt mower
   / belly mower to 3pt mower #11
The gearbox on your mmm is probably 1:1 (like my JD mmm). The RFM version using the same deck components is about 1:3. Have you looked into buying just the gear set? Change out the 1:1 and put in the 1:3. The gearbox housings look to be common, but I'm not sure about the Kubota mid-pto turn direction vs. the JD. . If not, I've seen a few complete gearboxes (used) on eBay.
Then you need the brackets and a drive shaft.
If you already have the mid to front pto kit (lets say for a snowblower), AND you have some fab skills, consider using that deck for a front offset mower. Its a cool wayto get under the pine trees without getting your face slapped by sap filled braches. You could make use of the FEL frame to do a QA rig, or just push it from a Rube Goldberg forward linkage.
   / belly mower to 3pt mower #12
But the input to the gearbox is also facing in the wrong direction.
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2022 Caterpillar 259D3 (A53317)
2022 Caterpillar...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
