Mowing Belly mower models for JD3320
/ Belly mower models for JD3320 #1
jbrandy
Western MD.
05 JD3320
I just recently bought a 2005 JD3320 with a 300CX loader. My tractor has midmount PTO and valve behind. Does anyone know what model of belly mowers will fit this. How hard is this install? I see some at an auction near me from a 4310-is this the same mower? I am looking for a 72" one. Will I have any problems with mowing with the loader attached? Thanks for any suggestions/help.
/ Belly mower models for JD3320 #3
Yes, the 72" 7-iron is what you need. The mower for the 4310 is the same, but the attaching brackets will be different. You should talk to your dealer, it can get very confusing trying to figure out what brackets you need.
/ Belly mower models for JD3320 #4
I have a 3320 with the 72" 7 Iron MMM. There is also the matter of needing a 3rd SCV (which I think you already have) and a hydraulic lift kit to raise and lower the deck. Don't forget that.
When you ask how hard is it to install, do you mean for the first time? I have no idea on that since it came from the dealer with everything hooked up. As far as taking it off and on, it's a piece of cake in my opinion. About 7 minutes or so.
I know the 7-irons are rather pricey. But they are tough, and they leave a very nice cut. My only beef with it is that I wish it would raise a couple inches higher for transport.
Best of luck.
KB
/ Belly mower models for JD3320 #5
KB has it perfect.
Another vote for the 72" MMM 7-iron. Love mine!
/ Belly mower models for JD3320 #6
BloomingtonMike said:
KB has it perfect.
Glad to hear this. I ordered the 72" 7-Iron but had also given serious thought to GM2072R
Thanks for the info---does anyone know the model number for the deck and attachment kit? There is a mower deck Model # LVB25280 nearby up for auction and I wanna make sure it fits before I bid. Thanks
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
