Belarus 400AN
/ Belarus 400AN #21
You can buy Delco starters on e-bay for much less money than a new Belarus starter.
/ Belarus 400AN #22
Hydraulic leaks on Belarus tractors is a very easy fix! The factory uses copper washer seals on the many banjo fittings in the system. Get ahold of some domestic washers that are made out of softer material and problem solved.
/ Belarus 400AN #23
If the cooling fan belt is tight, and there is no clutter where the air passes through the cylinders, you can NOT over heat an air cooled Belarus. If it is well maintained, it will run very cool.
/ Belarus 400AN #24
Dude, 12 year old thread.
22in Mini Excavator Bucket Attachment (A61572)
22in Mini...
2019 PITTS LB35-33CS CUSTOM DELUXE LOWBOY TRL (A64276)
2019 PITTS...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
iDrive TDS-2010H...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
