Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #1
fieldgoal00
Metairie,LA
BELARUS 400AN
I'm purchasing a hydraulic toplink for my Belarus 400A tractor. I need to know the hydraulic connections prior to ordering. Does anyone know if these factory connections are 3/8" NPTF or SAE 8? I've included a picture to aid in an answer.
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #4
While the 2" dia unit will work for you, I highly recommend that you go with a 2 1/2" unit for your size tractor.
why would you recommend 2-1/2" diameter?
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #6
With the size-weight of your tractor, if you do any work in reverse, such as box blading, rear blade work etc, you can very easily bend the 1 3/16" dia rod that that unit has. :(
John Deere MX10 Rotary Cutter (A53117)
John Deere MX10...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
40ft Sea Container (A52384)
40ft Sea Container...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
