Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #1
fieldgoal00
Metairie,LA
BELARUS 400AN
I'm purchasing a hydraulic toplink for my Belarus 400A tractor. I need to know the hydraulic connections prior to ordering. Does anyone know if these factory connections are 3/8" NPTF or SAE 8? I've included a picture to aid in an answer.
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #4
While the 2" dia unit will work for you, I highly recommend that you go with a 2 1/2" unit for your size tractor.
why would you recommend 2-1/2" diameter?
   / Belarus 400/420 Rear Hydraulic connections for Hydraulic Toplink #6
With the size-weight of your tractor, if you do any work in reverse, such as box blading, rear blade work etc, you can very easily bend the 1 3/16" dia rod that that unit has. :(
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
