Belarus 250AS Wiring Diagram
   / Belarus 250AS Wiring Diagram #21
I know this is an old thread but does anyone happen to have a picture of the correct wiring for a 5 post belarus 250as? Someone monkeyed with mine before I got it and put in a push button starter. I purchased a new ignition switch and want to connect it but the yellow, black, and blue wires are not connected. I think the yellow, and black go to the headlights (hi and low) and the blue is for the brake / marker lights. Also once connecting the starter solenoid wire to the solenoid instead of the bypass wire there are trace amounts of electricity (few millibolts) always present. Is that normal or is the relay shot too?
   / Belarus 250AS Wiring Diagram #22
The socket below the ground switch is for a 12v drop light that used to be included in the tool kit that came with the tractor years ago. Some idiot sued Belarus over a free tool, so they just stopped giving them out. As for the leaking hydraulic line, I am sure Belarus would be glad to sell you a new one, 800-356-2336, but I would find a tig welder and just patch it.
   / Belarus 250AS Wiring Diagram #23
I don't know about a "socket" near the ground switch. Take a pic. The remote hydraulics are controlled by the right most lever and are for operating single or double acting remote cylinders. The lever has four positions, raise, neutral, lower and float. You will not need these unless you have a log splitter, FEL, or anything else that requires hydraulics not operated with the three point. For patching the hole, just slide a piece of hydraulic hose over the pipe and use hose clamps to tigthen on either end.
The Belarus tractors use an old fashioned starter relay under the dash. When I was a dealer, I changed a lot of them. Any auto parts store should have a suitable replacement relay.
   / Belarus 250AS Wiring Diagram #24
Hello
What is the plug socket under the dash next to the main ground switch?..........its for a little mini trouble light.......my 250A Canada version had one in the toolbox........can send a picture if you want.
   / Belarus 250AS Wiring Diagram #25
I am having all of the same problems with my recently acquired 250. I know it’s been 14 years since this thread was started but is there any chance someone knows where I can get a bridge rectifier for it? I can’t find anything and I’m not sure what I can use that would work as a replacement. Any help would be greatly appreciated.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2016 KBAR 157595AL Pressure Washer Trailer (A51691)
2016 KBAR 157595AL...
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
1638 (A51247)
1638 (A51247)
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
