Beginners Luck: Stump Grinder Jammed with Wood Chunk
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a brand new stump grinder -- a Shaver SC25 model. I was using it for the first time this morning. On my sixth stump, it stalled my tractor when a chunk of wood got jammed between the grinding wheel and it's casing -- at the very back. I tried to engage the PTO and it stalled again. What's the best way to remove the jam without damaging the grinder? Does this happen often -- or is it just beginners luck?
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #2
Can you unhook the pto shaft and turn it backwards?
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #3
Another idea is can you disengage the pto and get a pry bar or board against the grinding wheel and turn it backwards but be careful you don't tear something up.
It will not budge. Looks like I will have to disassemble and remove the cutting wheel. The object is a big wood chunk and it is in there as far as possible. My stump grinding is off to a slow start.
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #5
Can you burn the wood chunk out? Just thinking out loud. Or get it wet and spongy.
Wedge
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #6
Can you get a wood chisel at the wood chunk and shave or slice it into pieces? I have successfully freed my wood chipper that way.
Sent from my iPad using TractorByNet
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #7
Every time I've seen this thread title today, I first think it says:
Stump Grinder Jammed with Wood Chuck
:D
I guess I've seen "wood chuck" hundreds of times more than I've seen "wood chunk."
Drill? Sawsall? Big pry bar? Angle grinder?
Lure it out with clover? :)
Bruce
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #8
Can't be that big of a problem. There has to be a shield or an open space to cut a relief to free the blade. More horsepower would cure this from happening.
When I get this cleared up -- I probably will run into a wood chuck!
No chance getting a tool in there to chisel or shave the object. I think burning it might be the best approach if I can find a propane nozzle that's 18 inches long, or so. Any chance this will generate enough heat to damage the cutting wheel or teeth?
   / Beginners Luck: Stump Grinder Jammed with Wood Chunk #10
If it was me- I'd be taking the blade out already. This way I can inspect for other damage while blade is off and check to see if there is any greasing or maintenance I could do.
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Yanmar YFL-1575 33HP Utility Loader Tractor (A49461)
Yanmar YFL-1575...
