Before I do too much damage! Iseki TX1500
   / Before I do too much damage! Iseki TX1500 #1
ESBkevin
Suffolk (UK)
Iseki TX1500
Good morning Ladies and gentlemen, further to my initial posting in the introduction thread this is my first real post, so please be gentle with me.
I have bought myself the aforementioned TX1500 which requires a little TLC.
So I have some questions for those that know.
In order to get at the dashboard electrics properly I need to remove the steering wheel, do I simply prise off the centre cap and undo the split pin/castellated nut? I don't want to crack the cap with too much force without being sure. It looks like it's not well seated at present and there might be what look like threads showing!!!
On engine oil change, is it good practice to prime/pre fill the new filter before tipping it on the side and screwing it on?
Front wheel bearings, (two wheel drive verion) although it drives well enough there is a lot of play in the front wheel bearings, my online reading suggest they can be adjusted. Anyone know the torque settings applicable or has anyone had to replace those bearings?
I have (thanks to the members here) downloaded the operators manual and the the parts manual so I'm just looking for a link to a workshop manual now.
Apart from the tractor and Rotavator, I have already added a 3 point hitch, a subsoiler, and a basic single furrow plough.
I have to admit this is proving to be a lot of fun and I might even get some jobs done too.
Thanks in advance.
   / Before I do too much damage! Iseki TX1500 #2
There is a lot of debate regarding the practice of filling a new oil filter. Sometimes I do if it sits vertical, but on a slant, adding oil will just leak out and make a mess. As far as front wheel bearings, I believe you tighten the nut as much as you can with just your bare hand, making sure that the wheel is fully seated. Assuming you have the tapered roller bearing style? I jack up the front end, then spin the tire by hand. If the rollers are shot, you will hear them clink around.
   / Before I do too much damage! Iseki TX1500 #3
They're great little tractors. If at all possible I would avoid taking the dash apart. Try removing the battery and having a look. One accessory I would look up is a set of three appropriately-sized suitcase weights for the front. The oil filter sits horizontally, doesn't it? Just change it and remember to put the filter on before you start it with its new oil*. Be sure you have established how much engine oil it takes and then give it that much.
*First oil change I was so busy fussing about the wrong things I forgot to install the filter and sprayed oil all over the tractor.
Thanks guys. I shall get onto this when the weather dries up a bit.
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
