Beaver leaking tran/hyd fluid from ?
   / Beaver leaking tran/hyd fluid from ? #1
DonE0929
N GA mountains
Mahindra 1526 tlb, Satoh Beaver S370D
Well I filled the trani/hyd fluid and everything started shifting and working great.... I parked it in the garage and last night I found all my fluid on the shop floor. It was dark but the fluid appeared to be leaking from a rubber plug on the rear of the housing... I puled the plug off but it was too dark (no flashlight)to see much. what is under the plug... there are no bolts anywhere around it...
I know I need a manual, but until I get one can someone tell me what is under that plug. I wont get to look at it again until monday, but I'd like to know what I am messing with before i get started.
Thanks in advance
   / Beaver leaking tran/hyd fluid from ? #2
Any chance you could get a picture of it loaded? Could it be leaking from somewhere else and flowing around the rubber plug?
ok.. so I just had to go out there before I went to work.... I look the drain plug out and drained out all the fluid which looked very much like my coffee ( with cream ) so a flush is in order. The leaking plug has a snap ring ( cant find my snap ring pliers ) so I assume there is a failing o ring in the mix.
   / Beaver leaking tran/hyd fluid from ? #4
Don: What did you find on that leak? I just got one of these, and I am having trouble figuring out where the drain plug is for the tranny... Can you help? Also give an update on the leak.
Thanks
RonZ
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2017 Ford Expedition SUV (A59231)
2017 Ford...
2404 (A60432)
2404 (A60432)
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
