Bearings in hydraulic fluid
   / Bearings in hydraulic fluid #1
bbd 25
North GA
KUBOTA 6800
I had very milky white hydro fluid in my Kubota m6800. Not ran it in 5+ months, had been running smooth, maybe a little hot at times but not over heated. Since it's white I figured It obviously is getting water in hydraulic system somehow. I changed it. When I did, inside the filter and where filter connects, was a lot of big and small metal pieces, looked to be from a race of bearings. Large bearing ball was on the edge and fell on down behind where filter connects.
Very discouraging. Have large fluid filled tires. Probably needing a clutch too. Don't want to pay dealership to do, because it needs split and I know thats gonna cost out the butt. I don't make much $ with it and don't have a farm yet. It's used to bush hog family land and help other family with hay and do a driveway here and there. So I'm at a crossroads. Sell it, and be up front with buyer. Take it to dealership and drop $2500+- or figure a way to get tires off myself and start tearing into it.
Any suggestions?
   / Bearings in hydraulic fluid #2
Get a second person to assist with the tires. Keep them upright and roll them around and prop them up against a wall or something. Or unload them. Either way I'd look into it myself, but I dont know your abilities or tool selection or shop setup
   / Bearings in hydraulic fluid #3
maybe you have friendly neighbors that will help with tractor work while you save $$$money to get yours fixed?..
   / Bearings in hydraulic fluid #4
I don’t think you have to take the tires off depending on the repairs needed. I’ve split 2 tractors and left the tires on both times.
   / Bearings in hydraulic fluid #6
As 4570 said, a lot easier to split if you leave the tires on if you can, trolly jack and you can move it around..............Mike
   / Bearings in hydraulic fluid #7
Been there done that.
As long as you keep those tires upright you can roll them out of the way easily, LOL, just don't drop them.
Actually when U return them the bolt holes should still match up.
Thank you everyone, I do have a workshop manual downloaded. I appreciate everyone's input. I'm going to fix it best I can. Then sell it or trade it in. After I fix it I don't want it to be in the back of my head every time I take it out that the pump or something may go out due to pieces of shrapnel I didn't get.
In the meantime, if anyone knows where or why bearings would be in the hydo system then please let me know. It may save me a ton of time.
   / Bearings in hydraulic fluid #9
Funniest thing I heard or read all week. That’s a great theory you have there. It works IF you roll the wheel away and back EXACTLY the same distance. To the inch or less.
   / Bearings in hydraulic fluid #10
Ditto
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
Mulch Spreader (A50120)
Mulch Spreader...
(250) Safety Traffic Cones (A50121)
(250) Safety...
Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 410L...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
