Bearcat 70554 Problems
/ Bearcat 70554 Problems #1
kornowsd
Spicewood, TX
John Deere 5055E
Hi;
I have had a Crary Bearcat 70554 chipper/shredder for a while and, as of late, it's developed a bit of a problem. This unit has chipped/shredded 1000's of pounds of brush, so it's not new by any stretch of the imagination. There are 4-chipper knives on the large flywheel, two knives on the interior of the flywheel, two of them on/near the exterior. One of the exterior knives has taken to nicking the anvil every rotation... note that it is only ONE of the exterior knives and not both of them and it is NOT the entire anvil, it's just the "back" corner, nearest the edge of the unit.
Yesterday, I stripped this thing down to the frame, removed the belts and loosened the lock collars on the flywheel (both sides) and grabbed a long-handled, 5 pound, rubber mallet. Grabbed the handle with both hands and swung at that axle shaft until I was exhausted. The shaft/rotor moved a small amount as the blade didn't stick quite as much. No amount of force, with the hammer, changed the shafts movement after that point but it was better. So, I reassembled the unit, put on a fresh set of belts and fired it up. It was WORSE when it was all over and done.
The question, now, becomes - How do I loosen that shaft to allow the rotor to move within the chipper cavity? Knowing the issues that could result, I even grabbed a five pound sledge and hammered that shaft. I am aware and accept the issues of having done that. That didn't budge the thing, either. The other issue, with this thing is, if I move that shaft/rotor, toward the front of the unit, one of the outside knives, and two of the inside knives are going to have a bit more clearance than the specified 1/8" while the one knife that's hitting the anvil, will be correct.
Some other points to note about the unit. The metal, around the 3-point hitch connections has fatigued, considerably, and the pins and forked 3-point arm, have sagged quite a bit. Many of the bolts, and even the frame in/around the shredder screen has, seemingly, sagged to the point where it's hard to get the screen out of the unit any more. The "anvil" (if that's what it's called) in the shredder portion (just above the shredder screen) is somewhat bent upward in the middle, as well. This unit has been well-used, obviously.
I've looked at the flywheel, on the side with the knives. That wheel is true/flat all directions I've had opportunity to measure it. So, I'm not entirely convinced that flywheel is "bent" just by the one knife. The bearings, for the rotor, rotate smoothly, there is no end-play, and they don't move back/forth and/or up/down. They're tight and if I remove the chipper knives and give the rotor a small tug it'll rotate slowly about 10 revolutions before finally stopping. Each revolution is smooth and quiet with no obvious sticks, or bumps.
Do I now just use the units adjustments "against itself?" Do I grab the pillow bearings on the shaft connected to the PTO and square them to the anvil, with a slight tweak "to the outside" (front bearing further out from body than the rear one???) to compensate for the pressure of the belts? This could, possibly, pull the chipper frame/anvil back into square and stop the blade from hitting the anvil edge??? Or, is this unit a bit too far gone to even spend time with??? Repairable, or buy a new one? I'm out of ideas with this thing...
Thanks for any thoughts/help you might be able to provide. They're greatly appreciated.
Darwin
/ Bearcat 70554 Problems #2
It seems to me - If you are sure the fly wheel is flat, all the knives are flat, the same thickness, and seated cleanly and properly on the fly wheel, then the shaft must be bent to cause only one knife to hit.
You said you loosened the lock collars. Did you just loosen the set screw or did you also use a punch and hammer to rotate them opposite the shaft rotation so they actually unlocked and could be removed.
Hey Gordon;
Thanks for the response. Set screws were removed, lock collars were loosened in the direction opposite flywheel rotation and they spun freely on the rotor shaft and moved back and forth, a bit. They were very loose. I sprayed WD-40 into the bearing/shaft junction, both ends, to loosen that up. In fact, looking at the design, if I want to move the rotor away from the rear of the machine, I should only have to loosen the rear collar - in the very first instance, just to get the thing to move. I need to loosen the front collar, once I've driven it through, to lock it into the new location, obviously...
I even knocked hard on the actual shredder body to get the bearing to drive loose from the shaft - I've seen that issue on some older equipment where the body panel bulged out/in and you had to bang on the panel to get everything to come loose. To no avail that way, either. Not sure what's locking that shaft to those bearings.
I called the local Bearcat technical rep. He tells me that the shredder box (PTO weldment is what Bearcat calls it) might be out of square and that's causing the issue. I called Bearcat, direct, and they told me that box can be substantially out of square and it will cause no issues to be so. So, contradictory information there. That said, though, I think that the actual Bearcat guy might be a better resource for that. He, also, didn't think that I could bend the flywheel. His thought was that my knives weren't sharpened evenly, causing only one of them to hit the anvil... that said, I can put ANY of my 4 knives in that position and they all do the same thing, so...
So, again, I'm at a loss. I can't say as the Bearcat tech offered me anything new/substantial to go with. Still frustrated with this thing...
Dar
/ Bearcat 70554 Problems #4
So you don't agree that the shaft must be bent or the axis of the shaft is not perpendicular to the fly wheel surface. Seems like that would make one one blade hit.
You know, it's entirely possible that the shaft is bent. It sure as heck would make sense in terms of not being able to drive the shaft toward the front of the machine if that were the case. I guess I'll have to go out there with my engineers square and have a gander at the shaft-to-rotor square... Any other thoughts on this thing???
Thanks.
Dar
/ Bearcat 70554 Problems #6
Either the wheel face is not longer true or the shaft is bent. There's no way for only one knife to hit without either of the two being the case.
Is there any play in the bearings, that you noticed?
Matt
/ Bearcat 70554 Problems #7
Some pictures might help people see what you are talking about.
So... I spent some time, this morning, making some measurements on the thing. I marked a spot on the weldment casing, on the anvil side and grabbed a tape measure with 1/64" divisions. I rotated the flywheel until the first outside blade was lined up with the mark and measured the distance from the weldment to the blade. Then, I moved the flywheel a bit and measured above/below the blade. I rotated the flywheel 180 degrees and measured the same three spots on the opposite blade. The averaged difference was 3/64 of an inch. Not much but just enough to have the blade nick the anvil.
Now the problem, here, is getting that shaft to break loose from the back bearing and/or the front one - whichever is sticking. I grabbed my rubber mallet, today, and loosened the collars one more time and beat the living shinola out of that shaft. In fact, I hit the thing hard enough, a couple of times, to cause my John Deere 5055E (hooked to the shredder) to move a bit with the transmission park engaged! The shaft never budged. I tried driving the shaft the other direction, from front-to-back, with the same end-result. I guess, now, the question is, how to free that shaft from those bearings w/o destroying the bearings, or do I need to destroy them, and put new ones in to get this thing to work? Or should I get the proverbial bigger hammer and give the thing a stronger nudge????
I was going to try to get photos however all I have is a professional dSLR and a flash w/o remote capability. I can't get the camera/flash situated to get a quality photo of that interior. I don't have a flashlight strong enough to light up the interior to assist with the lighting, either. If I had one of those tiny point and shoots I would have, possibly, been able to shoot the shot.
Any thoughts about freeing up that shaft from the bearings?
Thanks.
Dar
/ Bearcat 70554 Problems #9
Try Kroil or Ed's Red penetrating fluid and let it sit for a while.
With the amount of work that the chipper has done the likelyhood that sap and/or moisture has caused some corrosion.
If all else fails, try some heat. An O/A torch would be best but a propane hand-held might work if you can get the shaft and bearing hot enough. You may have to replace the bearings but it may be indicated anyway.
/ Bearcat 70554 Problems #10
This is what my shredder blades look like on my 3pt BearCat.
If you are talking about the two large shaft bearings, I had to crack the bearing housing and then use a Dremel to grind a slot and then knock the bearing inside collar off.
Well, quick update on this thing. I had a guy that specializes in restoring old/classic cars from junk piles to finished products c'mon over and take a look at this thing. I figured if anyone could figure out the bearing situation, and some basic alignment things it'd be someone that works, professionally, on stuff like that. Long story short, the two large shaft bearings are, pretty much, integrally attached to the 1 1/2" shaft that runs through the flywheel. He looked at it with a much more practiced eye than what I have and determined that the flywheel shaft is straight, and true. However, the flywheel, on the knife side, is truly bent. How you can bend a piece of steel nearly and inch thick, like that, is beyond me, but it's bent. Looking a bit further, he was also able to determine that the PTO weldment, near the anvil, is bowed inward, causing the anvil to bow with it and raising the back edge of the anvil ever so slightly. That, coupled with the flywheel is causing one of the knives to nick the anvil, and the other three not to.
Given that, the cost of the new bearings (I'll have to completely destroy the ones on there), and the cost/time to replace the bearings, he suggested that I grab hold of the feed chute with something, and raise it upward. That will cause the bottom of the chute, right near the anvil, to pull outward, flexing that inward bulge back out, straightening the anvil. Follow all that??? LOL. So, I grabbed myself a cheap tie down strap and put it around the front of the PTO weldment casing and the chipper feed chute. I cinched the thing up as best I could and flexed that chute in an upward direction. The knife stopped nicking the anvil.
What it looks like, is that when the knives were dull - the last time I chipped with this thing, it grabbed a rather large stick and drug it into the base of the feed chute. This metal, on this thing, is fatigued enough as it is, and that flexed the entire thing inward causing the anvil to hit the knives. Granted, there was, also, a time prior to that, where a larger piece of wood, somehow, lodged in the interior of the flywheel, and bent it outward, as well. Sometimes, I think, it's just time to hang this thing up and call it quits.
To replace the bearings I'm either going to have to bring this to a shop ($500+ repair, with parts/labor), or buy myself a torch and find a bunch of time I don't have. Lesson learned, I guess, is that when this thing isn't in use, I need to pull those bearings and keep them clean so that when I need to actually pull them, for real, I can move them.
Thanks for the thoughts/ help.
Dar
/ Bearcat 70554 Problems #12
Did you read any of my post about how I removed the bearings. Did not take that long.
Two or 4 bolt flange bearing cost less then $20 each.
Interesting on the bearing price. I was quoted, by 3 different dealers, here, $49.50 ea., plus tax, on the bearings. These same three dealers charge $75/hr to knock those old bearings off, put the new ones on. Most are quoting me a minimum of four hours to do that PLUS final adjustments when all the new parts are in... total, out the door, $500. I guess I could try to shatter the old bearing housings and cut the collars, like you did. It's just, right now, the amount of time/effort I have to put into this thing to get it done. I was thinking it might be a bit quicker/easier than what it's turning out to be. It's almost easier to just buy a new one and throw this one in my dumpster... that's my frustration speaking, right now, to deal with.
Thanks for the help. I just need to figure out where to go with this thing and whether or not it's worth spending the money on or if I'm going to fix this and then end up, down the road a bit, with more, or similar problems.
Dar
/ Bearcat 70554 Problems #14
/ Bearcat 70554 Problems #16
1.5" Pillow Block Bearing
Bust the cast housing, knock all the bearings, take it down to the inner race.
Use a Dremel tool with cutter disc or a 4 in DeWalt side cutter and cut the race off.
You know you can do, and save yourself a bunch of bucks.
If I was close enough, I would do it for you.
Nothern tools, $16.00
pillow block bearing from Northern Tool + Equipment
Heck, for the price you were quoted for the repair, you could fly J_J to your place, have the repair done, and save some bucks.:laughing:
/ Bearcat 70554 Problems #17
The flywheel is 125 lbs and chipping generates lots of vibration. Seems like a lot to ask from a $16 bearing w/o specs. But I don't know. I am just wondering. I see 1.5" bearings in McMaster Car with specs on them that run $100 to $400 depending on the dynamic load and other things I don't understand. I guess I would not want that fly wheel to come loose when I was anywhere near it.
/ Bearcat 70554 Problems #18
You would think that since Northern Tools has been selling these bearings for about 20 years, if there were any problems they would have pulled the product.
/ Bearcat 70554 Problems #19
That is a good point J J. I wonder how many go on such a heavy duty application. I really have no idea how suitable they are I just thought it was a reasonable question ask. They are cheap enough that you could replace quite a few sets and still be ahead as long as they didn't let the fly wheel tear a lot of stuff up if they failed.
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
1996 Lincoln Town Car Sedan (A59231)
1996 Lincoln Town...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
