Beacon plug? xr3135hc
   / Beacon plug? xr3135hc #1
ismilelots
Beaverton, MI
LS 3135hc
I have a xr3135HC and at the rear corners of the outside at the top of the cab there is a flip down cover. I was wondering if that was a plug-in location for the beacon lights.
If it is, can I buy just the plug? Or is it only available with the beacon? (I want to use the beacon switch to power a different attachment)
   / Beacon plug? xr3135hc #2
That’s it.
A while back, I’d guess a year or so now, someone here researched that plug and posted where to get it. It’s a very particular connector, but it is available.
   / Beacon plug? xr3135hc #3
Is it smaller than a regular cigarette lighter socket?
It might be the Hella socket then.
Something like this:
Thank you. I tried searching the forum but didn't see any posts on it.
Your help is much apreciated.
   / Beacon plug? xr3135hc #8
That's it but you need the low profile one that bends 90 degrees or you will not be able to open the side window with it plugged in.
Hydraulic Breaker (A55973)
Hydraulic Breaker...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2019 Deere 550K (A53317)
2019 Deere 550K...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
