Be careful cutting dead/standing trees...
   / Be careful cutting dead/standing trees... #11
   / Be careful cutting dead/standing trees... #12
   / Be careful cutting dead/standing trees... #13
That's not safe. Even with your extending boom and grapple, if you were pushing on a tree and something snaps of breaks away quickly, you could get whiplash in the upper part of a taller tree. If there is a weakness up in the tree, it can break off and fall on/toward you.
Yep, I know that from nine years ago. When I was dragging dead trees to the burn pile, that I had pushed over with the tractor.
I saw a old dead one and tried to push over with the TORO, it moved a little, so I backed up and ran into it, The top ten feet broke off and landed right next to me! :eek: Two feet closer and I wouldn't be here now.
From 2009 before I put the loader on it,
At least now I have FOPS! (Falling Object Protective Structure):D
I usually push them with the stump bucket, it gets me farther back, out of the way. :thumbsup:
And I can pick them up and move to the burn pile.
   / Be careful cutting dead/standing trees... #14
Thanks for the reminder. I usually run the chainsaw alone. Where I am, buzzards would be circling before anyone made it this way to check. Might rethink that now.
   / Be careful cutting dead/standing trees... #15
That's quite a machine, but still, pick your battles carefully. :thumbsup:
   / Be careful cutting dead/standing trees... #16
Yep, thanks. I learned not to bump into dead trees! :laughing:
I used it a lot dragging stuff to the burn pile.
Some cedar limbs.
With the loader added to it, I could carry limbs and make bigger piles! :D
   / Be careful cutting dead/standing trees... #20
Nothing but good advice on this tread. I've pushed over trees with a rented T-190 and will do so again in the spring to extend a food plot. Here is what I do I dig with the bucket on the side I want the tree to fall then I go on the other side and push with the bucket as high as I can, I do not push hard and if it doesn't work I will go and dig out more. The biggest tree I have done this to is a 15" diameter cherry most are 8" to 10" ash and elm.
2206 (A58376)
2206 (A58376)
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
Jacobsen three wheeler Reel Mower (A56857)
Jacobsen three...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
Mini Plate (A57149)
Mini Plate (A57149)
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
