Be careful cutting dead/standing trees...
   / Be careful cutting dead/standing trees... #11
   / Be careful cutting dead/standing trees... #12
   / Be careful cutting dead/standing trees... #13
That's not safe. Even with your extending boom and grapple, if you were pushing on a tree and something snaps of breaks away quickly, you could get whiplash in the upper part of a taller tree. If there is a weakness up in the tree, it can break off and fall on/toward you.
Yep, I know that from nine years ago. When I was dragging dead trees to the burn pile, that I had pushed over with the tractor.
I saw a old dead one and tried to push over with the TORO, it moved a little, so I backed up and ran into it, The top ten feet broke off and landed right next to me! :eek: Two feet closer and I wouldn't be here now.
From 2009 before I put the loader on it,
At least now I have FOPS! (Falling Object Protective Structure):D
I usually push them with the stump bucket, it gets me farther back, out of the way. :thumbsup:
And I can pick them up and move to the burn pile.
   / Be careful cutting dead/standing trees... #14
Thanks for the reminder. I usually run the chainsaw alone. Where I am, buzzards would be circling before anyone made it this way to check. Might rethink that now.
   / Be careful cutting dead/standing trees... #15
That's quite a machine, but still, pick your battles carefully. :thumbsup:
   / Be careful cutting dead/standing trees... #16
Yep, thanks. I learned not to bump into dead trees! :laughing:
I used it a lot dragging stuff to the burn pile.
Some cedar limbs.
With the loader added to it, I could carry limbs and make bigger piles! :D
   / Be careful cutting dead/standing trees... #20
Nothing but good advice on this tread. I've pushed over trees with a rented T-190 and will do so again in the spring to extend a food plot. Here is what I do I dig with the bucket on the side I want the tree to fall then I go on the other side and push with the bucket as high as I can, I do not push hard and if it doesn't work I will go and dig out more. The biggest tree I have done this to is a 15" diameter cherry most are 8" to 10" ash and elm.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
air compressor (A55758)
air compressor...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
