BCS735 mods
/ BCS735 mods #1
oldmech
Quebec
Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
Hi ! Two weeks ago. I finnish mowing and come back at home. Bang! The PTO lever quit the U stand and go in and turn around the wheeel. result A rod PTO lever bend and the shift lever bent. I was lucky the PTO fork in trans was ok.
The BCS lever system for gears and PTO are very fast for change but not very safe . The lever rod can quit and go in wheels with front implement. Can need expensive repair.
I add a device for hold the lever rod . Easy and inexpensive to make. I use 1/16 x 1 in. steel plate about 5 in.
Good luck !Oldmech
/ BCS735 mods #2
Oldmech, you have created a good design. You are correct regarding the BCS transmission shift and PTO links being very fast for change but easy to jump out of the plastic bracket.
/ BCS735 mods #3
Oldmech, that is a great idea. Just had to straighten my shift lever, not the first time. That little strip of metal should solve the problem on my 850.
Thanks
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
