BCS 853 quick attach loose
/ BCS 853 quick attach loose #1
jrpeterson05
Riverton, Utah
BCS 720, BCS 739
I just picked up my new 853 and I put my old quick attach coupler on it. It bolted easily onto the tractor and the tiller attachment. However I am noticing quite a bit of play in between the tractor and the attachment. Is this normal? I didn稚 ever notice this on my old tractor.
/ BCS 853 quick attach loose #2
Hmm, according to EarthTools you shouldn't have a problem: PTO Accessories - Earth Tools
are you noticing horizontal play or vertical? On our 732 the tiller connects with no play and the flail-mower only has the built in horizontal movement.
/ BCS 853 quick attach loose #3
If you moved both male and female sides of the coupler to the new tractor and tiller, then I don't see how things would change. If it's the coupler to couple connection that's more loose, maybe you mounted the male side 180 degrees from how it was originally and that made a difference.
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
2007 DRAGON 130BBL STEEL (A63569)
2007 DRAGON 130BBL...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2001 John Deere 1760NT Planter (A63109)
2001 John Deere...
2022 John Deere Z930M (A57148)
2022 John Deere...
