BCS 853 quick attach loose
/ BCS 853 quick attach loose #1
jrpeterson05
Riverton, Utah
BCS 720, BCS 739
I just picked up my new 853 and I put my old quick attach coupler on it. It bolted easily onto the tractor and the tiller attachment. However I am noticing quite a bit of play in between the tractor and the attachment. Is this normal? I didn稚 ever notice this on my old tractor.
/ BCS 853 quick attach loose #2
Hmm, according to EarthTools you shouldn't have a problem: PTO Accessories - Earth Tools
are you noticing horizontal play or vertical? On our 732 the tiller connects with no play and the flail-mower only has the built in horizontal movement.
/ BCS 853 quick attach loose #3
If you moved both male and female sides of the coupler to the new tractor and tiller, then I don't see how things would change. If it's the coupler to couple connection that's more loose, maybe you mounted the male side 180 degrees from how it was originally and that made a difference.
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
Cub cadet LTX1045 Lawn Mower (A63116)
Cub cadet LTX1045...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
John Deere 6400 Tractor w/ Bush Hog M446 Loader (A64047)
John Deere 6400...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
