BCS 853 ordered!
/ BCS 853 ordered! #1
Sparkeee24
Washington
Kioti RX7320 PCC
Hello everyone!
I would like to thank you all for your advice on two wheel tractors. I decided to go with an 853 electric start with the honda engine. I ordered up the 30" blade runner with the optional roller added, 30" tiller, and the older style 32" barely used bcs power harrow. I also am getting the 22 x 6.5 tires, foam filled, and root digger, ridger, hiller furrower, 5.5" extensions, and barbell hanger for wheels. I might get an aldo biagioli cultivator set too, but not sure yet. I may need to look into additional tire/wheel/extension/ track options later. We will find out!
Thanks again folks, can't wait to put it to use! !
/ BCS 853 ordered! #2
Congratulations! When do you take delivery? Post some pictures if you can, please.
/ BCS 853 ordered!
I should be getting the majority of it in first week of January, as the shop is closed for holidays. Today, I took the old motor of my troy built horse, and am working on getting an HF predator 212 motor on it, to sell, or give to brother in law...but I'm finding it's been pieced together I think. It has two different wheel assemblies, so tires aren't centered on tines. Sheared the first bolt i went to remove from on top of motor mount pin... might look into seals for tiller ... Spring will be here faster then we think!
/ BCS 853 ordered! #5
Congrats - bought one last year and love the machine!
/ BCS 853 ordered! #6
From what I've read, the next thing you need is a rotary plow! I recently purchased a new one off ebay when ebay had a 10%/$100 coupon. The $1050 price was too good to resist. I've been unable to try it out yet, though, because I'm also waiting for Earth Tools to get back Jan. 2 to send the j-connector for weights. I need to add rear weight to my 948, because it is too front heavy.
/ BCS 853 ordered! #7
I needed to add some weight to my machine as well. I just made a bracket and welded a threaded pipe on it then used a pipe cap with a bar welded on it to hold the weights on. Cost next to nothing and works pretty good for a quick adjustable system (you will find you want to weight each attachment slightly differently to get the right balance)
/ BCS 853 ordered! #8
I like your weight adapter, as well as the kick stand, but I need rear weights. The 948 has stock weights just behind the engine, so it is very front heavy. The 34" tiller requires a 3" extension to be balanced, bolted to the extension (there's no 3-bolt quick hitch). I've added a quick coupling onto the extension to use my other implements, but it is too front heavy. I went to use my snow thrower, and added a second 3" extension with both male and female quick hitches, and it was just to the point where the snow thrower would stay on the ground. I'm going to try j-bolting some weight to the tow hitch.
/ BCS 853 ordered! #9
I couldn't figure out how to send the pic when I posted the previous message. The snow thrower is pretty much neutral with this much extension. I don't want to take the weights off from behind the engine if I don't have to. Joel @ Earth Tools told me the 750 had the weights redesigned and they're not as much of a PIA.
/ BCS 853 ordered! #10
Wow, sure looks like a lot of torque on those cast flanges. Does BCS recommend that much of an extension?
/ BCS 853 ordered! #11
I haven't used it in that manner. I was trying to see how much I needed to get the snow thrower down from the clouds.
/ BCS 853 ordered!
I would not use it in that manner. The further the leverage point from the axle pivot you get, the less added weight is needed to counterbalance implement. I have seen some YouTube 2 wheel tractor videos with long extensions built onto opposite ends from implement to accept weights, but they only had like 20 lbs on it due to effective leverage. You could fab some thing like that up. Also, if you need the implements closer to the ground, shorter tires may be best solution.
/ BCS 853 ordered! #13
Congratulations! Ive owned an 853 for 2 years now. You'll love it. Very handy and very durable.
/ BCS 853 ordered! #14
That's nice. Ive been thinking about doing something similar on my 853. It seems like it would help with the stump grinder attachment that I have(very heavy).
/ BCS 853 ordered! #15
Thanks - really helps me get the right balance for the different implements and makes them much easier to use or transport.
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
John Deere 5525 (A60462)
John Deere 5525...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
Bobcat T76 Compact Track Loader (A64047)
Bobcat T76 Compact...
RoGator RG1300C (A63118)
RoGator RG1300C...
2010 MACK PINNACLE(INOPERABLE) (A63569)
2010 MACK...
