BCS 715 Tractor Clutch
/ BCS 715 Tractor Clutch #1
hwm
Bremen, KY
BCS 715
I just got my BCS 715 tractor out for the summer and the clutch will not release. If you want it to move you have to ram it into gear and to stop it you have to pull it out of gear. Anyone have any ideas how to fix it? HWM
/ BCS 715 Tractor Clutch #2
Do a search for rusted clutches and you will get your answers.
Bill
Bill, I appreciate your help. When I separate the engine from the transmission the clutch bell is mounted on the shaft of the engine. The clutch is in the transmission housing. Should the clutch come out of this housing or remain? I can't get to it to work with it in any way. Thanks:)
/ BCS 715 Tractor Clutch #4
I had to have a bearing put in my clutch and I just removed the four nuts on the back of the engine and lifted the motor off, the clutch came out with the motor. Take a six mm allen wrench and stick it in the end of the clutch pack and remove the bolt, it's right handed thread so it's easy to get off. Then this http://bcsamerica.com/pdfs/serviceinfo2-6clutchstuckinengaged.pdf will show you how to get it loose. Hope that helps.
/ BCS 715 Tractor Clutch #6
Milkman:
I recently bought a BCS605, used, not running [excellent compression by my compression gauge and a bright spark]. I do not believe it has been used in decades. I have disassembled and cleaned the carb, fuel tank, and the engine runs well. I have the rusted clutch problem. Clutch is stuck, engaged. I have seen
http://bcsamerica.com/pdfs/605.pdf
and
I use Haynes Automotive Repair Manual for my Ford repair needs. I find these manuals very helpful because they take me through disassembly / assembly step-by-step. Can you recommend a comparable BCS repair manual? This serviceinfor2-6 clutch repair may be beyond my abilities.
/ BCS 715 Tractor Clutch #7
Milkman:
The clutch tear down, cleaning and assembly were not difficult and tractor is running again. The throughout bearing in the clutch mechanism was easy to replace with a standard bearing available locally.
However I continue to look for a "Chilton's / Haynes - type" repair manual for BCS. I am looking forward to learning about any 'step-by-step, shade-tree-mechanic-type' repair manual suggestions.
I continue to make progress on this tractor. I have worked through the engine, clutch, and transmission with superficial mechanical repairs. The drive train is OK up to the slider. Currently I cannot drive, under load, any of the implements that came with the tractor . I bought a new slider and will repair the 'slide lever'. Hopefully that will be enough to get the PTO-driven implements operating properly.
BTI TB 1280XL Hydraulic Rock Hammer (A61166)
BTI TB 1280XL...
Mini Metal Standing Fire Pit (A61569)
Mini Metal...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
2021 John Deere 331G Compact Track Loader (A61166)
2021 John Deere...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2014 Volkswagen Passat TDI Sedan (A61569)
2014 Volkswagen...
