BBQ Smokers
/ BBQ Smokers #221
I've been enjoying smoked bluefish every night since Saturday. Sometimes mixed with soft cream cheese and sometimes straight up. Good eats. You westerners and country boys need to come to the east coast to try some. It is never frozen and doesn't last long so unlikely you'd ever find it in a fishmonger more than 50miles from the Atlantic coast.
/ BBQ Smokers #223
$27 delivered if you have Amazon Prime. (Note, the price changes several times a day but not by much). This is the folding instant read thermometer I like.
Ultra Fast & Accurate, High-Performing Digital Food/Meat Thermometer - Lavatools Javelin/T... https://www.amazon.com/dp/B00GRFHXVQ/ref=cm_sw_r_awd_vpq3vbA1NCEXC
If 150 was clearly overdone, you might even want to check it when it hits 125 on the grill. It will keep cooking for a while so will probably reach 130-135 by the time you carve.
/ BBQ Smokers #224
There ya go! It says it right in the link;
beef lamb veal; 125
poultry; 160
pork; 140
fish; 125
also said it will gain 5-10 deg when resting.
Lots to learn, but that 's half the fun! :)
/ BBQ Smokers #225
beef lamb veal; 125
poultry; 160
pork; 140
fish; 125
Those figures are good for grilling. Smoking sometimes has different target temps. Usually for example you would go significantly higher with pork you intend to pull. Smoked fish is often taken to something around 150-160 to get a "meaty" consistency but you could go much lower if you want a moist smoked fish. I haven't done a brisket but I'd bet those are cooked much higher than 125.
There are lots of good BBQ and smoking web resources that discuss what temp to use for oven and target internal temps. The "instant" thermometers allow you to check as often as you want to take the guess work out of the equation.
/ BBQ Smokers #226
Are you inviting us?
/ BBQ Smokers #227
:confused3:
I only added about 10 briquets twice during the 3.5 hours. I put one foil packet of soaked wood chips in there when I started, too and that lasted almost 2 hours. So I tossed in a handful of soaked chips right onto the coals two more times and it smoked nicely.
To soak -or- not to soak wood chips. The science of wood chips as presented by amazingribs.com Don't Soak Your Wood. This Myth Is Busted.
Much ribbery science on amazingribs.com BBQ Ribs Recipes, Barbecue Recipes, Grilling Techniques, Baby Back Ribs, Barbeque Spareribs, Outdoor Cooking, Rating Grills and Smokers
Don
/ BBQ Smokers #228
:confused3:
Don
Being a novice to this whole thing, I'll say this. I put a foil packet of chips in that I didn't soak. They burst into flames, made some smoke and were gone in about 10 minutes. I put a foil packet of wet chips that had soaked for about an hour. They took about 20 minutes to start smoking, and then they smoked for a good while longer than 10 minutes. :laughing: Anyhow, I threw in a handful of dry chips right on the coals, and they also burst into flames, raised the temp in the smoker quite a bit, and were gone in 10 minutes as well. So I threw a handful of wet chips directly on the coals, they started smoking in about 5 minutes, and they dropped the temp in the smoker a little bit, but not much at all. They smoked for about 20-30 minutes and when they were gone I noticed the smoker temp had risen a bit.
Nothing scientific for me yet. No recorded measurements. No thermometer on the fire or smoker. Only the dial on the Brinkman that says WARM, IDEAL, HOT. It tends to get to the high side of IDEAL very easily and stays there. Add some coals and it goes up. Add some dry wood chips and it goes up faster. Add some wet wood chips and it cools down. I did use a meat thermometer after two hours on the chicken and three on the pork loin just to be sure it was hot all the way through.
Anyhow, it was darn tasty both times. :thumbsup: I'm thinking about a turkey next weekend. :licking:
/ BBQ Smokers #229
Around here there's no shortage of mesquite trees. I usually find a good one and either give it a good trimming, or just cut it down all together.
I like to smoke all night. What I do is use a little charcoal to get the wood going, once I have some good mesquite coals going I will throw on some green wood, then she will smoke all night for me.
/ BBQ Smokers #231
I use (dry)wood chunks opposed to wood chips, the chunks smoke for a longer period. If you watch the wood chips they will burn.:laughing: close the lid to reduce the oxygen level. Wet wood releases steam (often mistaken for smoke) until the moisture cooks off. I have an apple tree in the yard, it's a prized tree. Not so much for the apples but for the quality of the applewood for smoking purposes. :D Be careful, be very careful. Cooking with aromatic smoke can be very addictive. Look what it's done to Island Tractor. :thumbsup: It's a beautiful thing.
/ BBQ Smokers #232
I bought some chips the first time. I now have some chunks for the next time. A few weeks ago I gave my neighbor some nectarine wood. He cut it into 2" sections on about 2-3" diameter branches. He said it tasted really good. From what I've read, about any fruit wood will do just fine.
/ BBQ Smokers #233
That size would be perfect for my purposes. (I edited my post above, added a sentence or two.)
/ BBQ Smokers #234
You guys mentioned Coho Salmon and we don't get that on the east coast. Trader Joe's has it frozen though so I have me some and will try to get around to smoking it this weekend. Should be finished with the bluefish by then.
I'm a bit torn between going for a lower internal temp with moist smoked fish versus a bit higher like I did with the oily bluefish. Anyone out there smoked Coho Salmon? How'd you do it?
/ BBQ Smokers #236
I've never done it. A family friend smokes his here in Indiana. It is incredibly tasty! If I catch any this year, I'm going to try this recipe...
Smoked Sockeye/Coho Salmon Step-By..
The pictures alone made me hungry! :licking:
Thanks, I just copied that recipe. Will need to scale it back given that I only have about a tenth as much fish as he smoked but the basic recipe seems good. Looks rather like Alton Brown's smoked salmon recipe with a few extras and using a low temp smoke for much longer than he did.
/ BBQ Smokers #237
Yeah I was reading low temp vs hot smoking salmon. I'll have to read more when the time comes.
/ BBQ Smokers #238
I think the goal of low temp smoking is to prolong the time fish will absorb smoke flavor. Frankly, while I like smoked fish, I see the smoke as similar to a spice and don't want to overpower the natural flavor. I would also like to taste the fish itself. I hot smoked the bluefish and have no complaints. Lots quicker too. A couple or three hours at about 180-190 worked well. I've only used electric to smoke fish. Too hard (for me) to keep precise low heat with charcoal over a short period.
/ BBQ Smokers #239
Made a meal of sausage and wings last night. First time for wings, so I just did a dozen or so just to try. I didn't want to get fancy, so I just hit them with some SPG and put them on after the sausage had been on for two hours. Kept them on for two hours flipping half way through. Grilled them on high heat for a couple min per side to crisp them up. They turned out great! :)
One thing though; couldn't get a read off my instant thermometer from the wings. They were perfectly done though.
/ BBQ Smokers #240
My theory is that low and slow cooking (near or below the boiling point of water) tends to retain considerably more of the the moisture that would be driven off at higher temps while breaking down the tissue. As for smoking wood, I never use green wood nor do I use chips nor do I soak mine.
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
Mini Skid Steer (A60352)
Mini Skid Steer...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
