Baumalight Brushcutt CP560
/ Baumalight Brushcutt CP560 #21
If I read the specs right, your tractor is wider than the BrushCutt CP560. Has this been an issue in backing through brush? I got all my 3PH tools 72" or wider, so I would always cover the tractor width, even with the wheels mounted "wide".
It's a little under the width of my tractor, but not much. I was looking at the 72" initially, that's what size my rotary is, but, for my use, smaller is better. I'm in the woods with it, the less space I need to maneuver, the better. If I was clearing larger areas, I probably would have gone for the bigger cutter, but I wanted smaller and cheaper (the price uplift to 72 is pretty small though, so it was more "smaller" that I wanted). I don't have issues with the size, but if I was using it like a bush hog, I would. It's a bunch of back and forth anyway, eat some stuff, come forward, chip it up, and then go back in. So it's not like a bush hog where you want to run long and straight, at least not for me, that's not how I'm using it.
/ Baumalight Brushcutt CP560 #23
I have always read that the 3 pt is there to pull stuff and pushing may put stress on parts not designed for pushing. For instance http://www.tractorbynet.com/forums/owning-operating/342682-3-point-hitch-damage.html.
Does Baumalight address this?
For example for my M4700 and Woods Bh70X backhoe Woods recommends a "Saf-T lok top link" which is basically a really beefed up top link.
No, they don't, but there's not much pushing stress at all on the 3PT. You don't even really feel it when you contact a tree, at least not on my tractor, and I'm at the smaller end of the HP/size range. Using my box blade (which has a rear cutting edge) is many times the force, so, if I'm going to break it, it won't be with the cutter, that's for sure.
/ Baumalight Brushcutt CP560 #25
Overtaxed: Have you experienced any issues with stabs puncturing your tires?
I had a lot of brush on my place when I bought it. The tractor and bush hog did a good job cutting it but I got to be on a first-name basis with the tire repairman.
/ Baumalight Brushcutt CP560 #26
Im curious... What kind of tires did you have and how worn? Side wall?
/ Baumalight Brushcutt CP560 #27
I don't know/remember the brand. They were pretty worn. One of them was in bad shape. I attributed the first flat to that so replaced it. The new tire also experienced a few flats. The side walls were in good shape, it was the contact surface that was decayed.
I think I'm past the bad part so should not have the issue until I get the one field out of CRP. That particular field is restricted to "Native Growth" or something like that. I just had a meeting with the CRP folks (they call you in to review the plan) and that field is not supposed to have cedar trees. I asked if I could cut them and was told "No, Native Growth until the end of the contract". She also said I would be required to remove the cedar trees if I wanted to re-new the contract. Frustrating but it is what it is.
When it comes time to cut that area, I'll probably hire a guy with a bull dozier.
Not yet, but I do have concerns. The good news, the left overs after the machine runs through are kind of "exploded", they are sharp, but it's like the stump was "ripped off" rather than cut, so it's a million little tiny pieces sticking up, not a single sharp cut like you'd get from a chainsaw or clearing saw. And I have ag tires, so that's better than turf, I'd think, but not as good as industrial tires. We'll see, no flats so far.
What does it cost to fix a flat on a tractor, just out of curiosity? Seems like that could be quite an operation, especially with loaded tires (which I have).
/ Baumalight Brushcutt CP560 #29
Ag or industrial tires?
/ Baumalight Brushcutt CP560 #30
My eyes fell out of my socket seeing this, no idea they existed! At 5k, it’s sure is tempting but I don’t have that kind of money but would be easily tempted if financing exists. I have 8 acres to clear out and got a grant of 6.5k to thin it out but it has been slow going. This beast would speed thing up for sure but with my 35hp Branson, not sure...
/ Baumalight Brushcutt CP560 #31
I ran over a nail with one of my Branson's front tires this winter. I took the wheel into the local tire place and they charged me $25 or so to patch it from the inside. A rear tire would be a different story, especially since mine are filled with Rimguard.
/ Baumalight Brushcutt CP560 #32
My repairs have been about $210 each time. My tires are not loaded with liquid. I've thought about it but would just increase the cost every time I got a flat and I've never felt the need for more weight.
I handle front tires but the rear tires are a whole nother matter.
/ Baumalight Brushcutt CP560 #33
I am wondering how well this will work with my L35. I have 43 acres, most still wooded but I am in no hurry to do much as I like having the trees and only do a little at a time. Looking at medium duty rotary cutters, possibly heavy duty/right of way, but this seems cool too.
/ Baumalight Brushcutt CP560 #34
it sure would be nice if you could put this on the front of a tractor, wouldn't have to turn around to see what you are doing
You should probably reach out to Baumalight, it's a cat 2 implement, so the first question will be, can your tractor lift it? Beyond that, honestly, I think HP is just basically speed with this cutter. If you can lift it, you can use it, just will have to go slower. It's all about getting those blades up to speed, once they are spinning, actually impacting a tree to cut it puts almost no load on the tractor. Grinding it up, like you see me do in the video, puts some load on my tractor, but it's nowhere near starved for power. Now, if you put it in the dirt, you'll feel the power, for sure. That lugs the tractor mightily. But actually using it for what it's intended for (IE, not a rotary style rototiller), I'd think you would be OK with less HP than I have (60, ~45 or so at the PTO). Let me put it this way, I can cut faster than I can position by a pretty significant margin doing what I'm doing. Now, if you're just going dead straight and eating trees as fast as you can, yeah, that will become HP limited, but I also can't think of many situations where you'd be able to do that (maybe a very grown up right of way?). For clearing underbrush, you'll spend as much time with nothing under the blades as you do actually cutting a tree, plenty of time to recover the RPMs for the tractor and machine.
I think that is the case with a solid 50% of my implements. I wish a 3pt/PTO in the front was more common, there are a lot of tools that would work better that way. This this would be beyond awesome if I could hook it up in the front on my FEL! Of course, then I'd need hydraulics to run it, which I could get from a PTO in the back, but it would be much more expensive. If my tractor just had a front 3PT and PTO, I'd use it at least a significant minority of the time; would be very useful.
/ Baumalight Brushcutt CP560 #36
The L35 is/was Kubota's industrial backhoe model. The 3 pt lift capacity is 2300+ lbs and it seems this machine weighs about 1600 lbs so I don't think that would be an issue.
If that's the case, I can't see why it wouldn't work for you, even at the bottom end of the HP scale. This thing works 90% by speed/centrifugal force, you get those blades and pan spinning, and ease your way into a tree, you don't even hear it/feel it in the tractor RPMs as you make contact. Now, when it "sucks in" the tree, that does impact the RPMs a bit, but again, as long as you go slow, I can't see it not working for you. Try not to hit too much dirt, that's what really slows it down!
To give you a comparison, I have an EA 72" rotary cutter that I use on some fields, cutting waist high grass with that rotary puts a whole lot more load on the engine than the Brushcutt does munching slowly through trees. Now, if I were to back up to stand a trees and mash the hydro pedal in reverse, I'm sure I could change that situation, but most people aren't going to use this thing that way; it has plenty of time to build up momentum again for me between trees.
IMHO, you'll be fine. You might still want to reach out to Baumalight, they are very responsive, and ask them. But I think it'll work for you.
/ Baumalight Brushcutt CP560 #38
Overtaxed, have you tried your cutter on downed branches or maybe a pile of limbs?
I haven't, other than what you see in the videos, cutting a tree down and then sucking that up. Kind of similar to a downed branch. What do you want to do with it, eat you way through a bunch of branches that are in a pile? If so, I'm pretty sure it will do it, but something with a closed back might actually be better for that, put the hog over it, lower it down, and let it munch its way through. The real "magic" of this thing is the way it cuts through trees and can take them down so easily. If you have that use case as well, I'd think this would be a good choice. If you're just trying to eat up things on the ground, I would also look at (and ask for other opinions) on a heavy duty brush hog that can take whatever branch size you're looking to eat up. Or a chipper, which will do a much, much better job than any kind of cutter in turning branches into mulch. The Brushcutt is great, but it doesn't eat down "mulch", it's more like "sticks and twigs" that are left after I use it. That's the big difference between this and a mulcher, a mulcher will eat all the way to the ground and it'll turn everything into smaller chips. Still not as small or nice as a wood chipper though, for downed branches, unless you're dealing with a bramble or acres of it, I'd think a chipper would be the right tool.
/ Baumalight Brushcutt CP560 #40
I suspect you're taking out almost all green woody plants/trees, not deadwood, correct? It seems the momentum you build with the heavy disc with the double edged blades make the chipping and then cutting work as a result of force tearing into the tree/brush, whatever the blades encounter? The undercarriage and sidewalls shown in the manufacturer's pic seem very beefy to withstand the 'shock factor' a brush hog is NOT built to take. Altogether it seems that backing up is less fun than going forward could be. I suspect some of that is a result of potential liability concerns on the manufacturer's part since the cutter throws big enough pieces far enough to do damage to bystanders, even ones supposedly far enough out of 'range' to not get hit.
How'd you do the first drone video with the drone stationary?
Good report and details; enjoy that beast!:thumbsup:
2014 HAMM HD+140I DOUBLE DRUM ROLLER (A65056)
2014 HAMM HD+140I...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2018 Hitachi ZX300LC-6N Hydraulic Excavator (A66734)
2018 Hitachi...
2018 JOHN DEERE 544K LOADER (A67714)
2018 JOHN DEERE...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
