battery
/ battery #1
bones25
charleston wv
2003 farm pro
I have a farmpro 2524 I need a new battery for it. Can anyone recommend one? With winter coming on I want to be able to start it without having to jump it every time. thank you
/ battery #3
OR... Get the battery with the highest cold cranking amp that will fit in your tractor's battery compartment.
High cold cranking amp will allow you to crank the motor a little longer on cold mornings.
/ battery #4
It is probably a group 27 battery(My Jinma 284 is...). As mentioned, look for one with the highest CCA, but you will probably find them all pretty similar.
/ battery #5
I have had good luck with "Duralast" batteries in my tractors." Advance Auto"
/ battery #6
I think I put a group 31 in my Jm354 Jinma a couple yrs ago. Kinda spendy seems like I paid $125 for it at the local Orielly's
/ battery #7
If you are looking for maximum CCA(cold crank amps) - I think AGM(absorbed glass mat) batteries will give the most. Brands such as Odyssey, Optima etc - they are also very expensive. A group 31 Odyssey AGM replacement battery for my tractor was $300. I couldn't swallow that big a pill - I went with a HD Duralast battery.
2005 Chevrolet Suburban SUV (A64194)
2005 Chevrolet...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2022 EZ-GO ELITE...
2012 MULTIQUIP DCA-7OU512 TOWABLE GENERATOR (A63276)
2012 MULTIQUIP...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
