Battery
/ Battery #1
stevevk
Oregon
Mahindra 2015
It is time to replace the battery in a 2005, 2015 HST. When I went to disconnect the positive cable, I found a post connector I am not familiar with - it does not have usual bolt like most other connectors. Is there a special way to remove this? (It looks like it might have been designed for a bolt, but there is none present).
I've worked around equipment most of my life but have not run into this type of connection.
Thanks in advance,
Phil
/ Battery
Thanks a lot for replying - it turns out it appears the mounting bolt was sheared, probably when installed. This gave it an unusual appearance thus throwing me off. I was able to drill it out and replace.
Pictures would help
