Battery Wiring Question
/ Battery Wiring Question #21
The only way three batteries can be used is either ALL in series (36v) or all in paralled (12v 3x's amperage). But never a combination as mentioned.
Either run on two batteries in series, get a 4th battery and run series-parallel with an even count, or get 4 6v batteries in series. These are the only options I see.
As to the charger....if you are actually measuring 36v....it probably is a 24v charger but I would want more confirmation. A 24v charger HAS to put out more than 24v or it would never charge. 24V via 4 6v batteries or 2 12v batteries is actually ~25.2v. Most 12v chargers run 14-16v. So I would think a 24v charger would be somewhere in the 28-32v range in order to charge.
/ Battery Wiring Question #22
Might they have originally been 8 volt batteries? They are not exactly common, but they are used on golf carts.
Aaron Z
/ Battery Wiring Question #23
I'm very familiar with older JD tractors that utilized four 6 volt batteries for 24 volts. The main reason four 6 volt batt were used instead two 12 volt batteries is high CCA 12 volt batteries weren't available so four 6 volt batt were used to get higher total CCA's. With today's high CCA 12 volt batteries I'd use two 12 volt instead four 6 volt batt or better yet change system 24 volt system over to 12 VOLTS. From what I read service life of today's 6 volt isn't very good.
/ Battery Wiring Question #24
There won't be any smoke how do you think the insides of batteries are made? They are cells in parallel.
Using 2 batteries in parallel just makes a bigger 12v battery. Another in series to those makes 24v.
Since they are now 2 batteries of different sizes the single one will discharge faster and will probably have a shorter life but it will work. It's not ideal but it will work.
There is a proper way to do it, though and you should try that. If you need 24v just use two 12v batteries in series and it will be fine. Large ahr batteries will probably provide as much runtime as the original ones.
Golf cart 8v batteries in series would allow you 3 large capacity batteries for 24v and this may be the best and proper way.
/ Battery Wiring Question #25
You need to read & comprehend what rutwad stated which I'll quote an excerpt of the rutwad's original post [/quote]I can hook them up for 24v by having 2 in series and the other parallel[/quote] If you don't understand then read OP's original post again. I'll guarantee that three 12 volt batteries attached together on a 24 volt wiring harness will cause SMOKE to the wiring harness!!!!!!!!! I did not state or imply it would smoke the batteries but it's very possible that that could happen.
/ Battery Wiring Question #26
2 12v batteries in series is 24v and a third in parallel is still 24v. How will that smoke the wiring harness?
/ Battery Wiring Question #27
The 24 V from the two in series will effectively try to charge the single 12 V battery wired in parallel by a reverse flow of current through it. Given the huge current available and the high voltage, it would likely overheat and boil off gasses, a potential of explosive levels. Makes no sense to do this. Don't do it.
/ Battery Wiring Question #28
I guess it depends on how he has it wired. If he's wanting 24v he can get it with the three but definitely not hooking up the 24v series set to a 12v from the 24' terminals. I was hoping he had used them all together as 24v, meaning 2 parallel to the one 12v series Making 24v.
/ Battery Wiring Question #30
How would he do that?
12v to 12v series is 24v.
Take two batteries and parallel them. Now you have one 12v battery. A large one with 4 posts. The terminals you use will be at the ends (of battery 2) with 12v DC between them. You can then connect the + of battery two to the - of battery 3 (series) and the leftover terminals are going to give you 24v DC.
/ Battery Wiring Question #31
I was not entertaining your extreme method of trying to utilize three 12 volt batteries on a 24 volt system OR what the advantage would be BUT If the batteries on each side of a 24 volt system ARE NOT close to equal in amperes even if there was no smoke one will have difficulty in getting the batteries to charge correctly by means of the implements alternator or generator. Batteries utilized in a 24 volt system are similar to a chain and are only as good as the weakest link.
Well I was brought into this situation only recently. Several months back I bought 3 12 volt batteries to replace the ones taken out (not by me). I brought them home and placed them back in the battery tray of the lift. My dad is struggling with medical problems and last week was his first attempt to hook the batteries up and requested my help. He said it was a 24 volt system. I never thought 3 12 volt batteries seemed right so I told him let me look online before we hook them up wrong. Turns out it is a 24v system and I know 3 12v batteries came out of it. I told him the previous owner may have changed something because it didn't seem right to me. But it has worked for years and I was trying to figure out how it may have been hooked up.
I hooked it up as 24v and it works. However I did not hook the charger up. It is putting out 36v. Even if I swap to 4 6 volt batteries I still wouldn't know how to hook the charger back.
I'm trying to reply using my phone. I will get to my computer shortly. Thanks for the input and your patience
/ Battery Wiring Question #34
Seems like others have said you have a 24v machine that uses 4-12v batteries, (2 in parallel that are in series with the other two). But you only run 3 batteries (2 in parallel in series with 1).
I believe a 24v charger should put out around 28-29 volts. Sort of like a 12v charger puts out 12-14 volts. So what is a 36vt charger and where did it come from? (Why wouldn't a "36v charger" (for 3-12v in series) would put out about 41v? -Doesn't matter, you have what you have. )
Seems like instead of charging at 29 volts you've been charging at 36v without incident?
/ Battery Wiring Question #35
Or put another way: most Info I find says 2.45 volts per cell is a healthy max. charge voltage (= 14.7v for a six cell 12v battery, and 29.4v for 12 cells (a 24v system) connected in series. Having more batteries connected in parallel doesn't change this).
Can you charge with 36v (3 volts per cell)? I guess you have been. But it probably causes a shorter battery life. This is where the chemistry inside the battery and the metal reactions get over my head.
/ Battery Wiring Question #36
I had not thought of the unusual configuration of wiring the third battery in parallel of one of the two in series either. Technically it is 24V but makes no sense to me and I would not do it.
/ Battery Wiring Question #37
When you run the batteries down on a hard start (or leaving something on) the single battery will completely discharge long before the parallel batteries because all current runs through the single battery while only half runs through each parallel battery.
When the single battery is discharged fully, the parallel batteries will then force current through it backwards. I think that can happen (been a long time since I studied the chemistry of lead-acid batteries) and it can't be good.
You should be able to look at the cables and see how they were connected.
I agree that two in parallel, in series with with one is not good. :thumbdown:
I brought that up in post #8.
/ Battery Wiring Question #38
But the original post said
"2 in series and the other parallel"
That says to me the "parallel battery" is parallel to the 2 in series.
/ Battery Wiring Question #39
Well I thought he would be smart enough not to do that! :shocked: That would put 24 volts on a 12 volt battery. :eek:
I took it to mean "2 in series and the other parallel with one of the ones in series". Which dosen't have any advantage over 2 in series.
2022 EZ-GO ELITE...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
Tri Axle Rolloff Truck (A64194)
Tri Axle Rolloff...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
Metal Sasquatch (A65583)
Metal Sasquatch...
