Battery Wiring Question
/ Battery Wiring Question #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
I'm not sure where to post this, so maybe here will be okay. My father has a Grove scissor lift SM2232E. I'm sure other options would be better but 3- 12 volt batteries were taken out of it and that is what we bought for it. I didn't unhook them. All 3 batteries are same rating, size, etc. The lift uses 24v. I can hook them up for 24v by having 2 in series and the other parallel, but is there a better way? Can I hook them up to get equal draw from all 3? Any benefit to 3 over 2 batteries?
/ Battery Wiring Question #2
I'm pretty sure the lift wants to have four 6V batteries.
/ Battery Wiring Question #3
Is there room for more batteries?
It is pretty uncommon for electrical equipment to have an odd number of batteries.
/ Battery Wiring Question #4
Is it possible that 2 batteries run one function while one battery runs another?
/ Battery Wiring Question #5
Seems odd to me as well, three 12v for a 24v system just doesn’t make sense. As mentioned, four 6v batteries would work better if there’s room.
/ Battery Wiring Question #6
When you run the batteries down on a hard start (or leaving something on) the single battery will completely discharge long before the parallel batteries because all current runs through the single battery while only half runs through each parallel battery.
When the single battery is discharged fully, the parallel batteries will then force current through it backwards. I think that can happen (been a long time since I studied the chemistry of lead-acid batteries) and it can't be good.
/ Battery Wiring Question #7
As previously stated. Somebody has previously blotched the wiring job. The scissor lift uses four batteries of 6V .
/ Battery Wiring Question #8
You should be able to look at the cables and see how they were connected.
I agree that two in parallel, in series with with one is not good. :thumbdown:
/ Battery Wiring Question #9
Those do come with four 6 V batteries that would be wired in series to get to 24 V
http://www.hedi.pl/files/b100.pdf
I don't know that wiring two 12 V batteries is series paralleled with two more 12 V batteries in series wouldn't work if you have the space for a 4th battery. I would NOT wire a single one in parallel to two in series, that doesn't even make sense. Leave out the 3rd and run on two 12 V in series if anything.
/ Battery Wiring Question #10
Batteries in parallel can lead to a number of strange problems -- It's highly unlikely it was designed to use any batteries in parallel.
/ Battery Wiring Question #11
Right. It is designed to work with four 6 V batteries in series to total 24 V. Wiring two 12 V in series and paralleling two more in series would "work" but is not ideal and should at least have separate fuses. In the OP's case, where he already bought the batteries, wiring two 12 V in series is proably the best unless his budget allows him to buy the four 6 V as designed.
/ Battery Wiring Question #12
Yep ... I would just use the two 12 vdc in series. Not as much total energy as 4 6vdc but it will work safely. Other than answering this specific question, my larger point is this ... batteries .. if used improperly can be dangerous. There are cases where batteries improperly used in parallel can over heat, burst in to flames and explode even if fused for their rated loading.
Sorry I haven't responded before now. Last night I found this. Well I wanted to attach pictures but they are too large. I'll try to resize on my computer later today and post.
This shows 4 batteries, but it had 3- 12 volt batteries when we bought it used. I can get 24 volts from the 3 batteries. But I have not hooked up the charger because I checked it's output with my voltmeter and it read 36 volts. So now that I have the batteries wired for 24 volts, how can I hook the charger up?
/ Battery Wiring Question #15
I am not seeing a picture. The third battery needs to be disconnected and the remaining two need to be in series. Do not operate it with three 12V batteries in any configuration
/ Battery Wiring Question #16
Where did the charger come from?
Does it have a nameplate with a model number and output ratings?
Any chance the motor was changed to 36 volts?
We need pictures, they have to be 1,000 KB or smaller and the total size of a group uploaded at the same time has to be 1,000 KB or smaller.
/ Battery Wiring Question #17
rutwad, if you must continue heading down the "gotta make it work with three 12V batteries" road, please wear a face shield.
/ Battery Wiring Question #18
I think if you attach two 12 volt batteries in parallel and one 12 volt batt in series on same electrical system you are going to see SMOKE and a lot of it.:thumbdown:
As TomSeller stated if it's a 24 volt system install four 6 volt batteries or I would suggest two 12 volt batteries because of less battery cable connections required.
/ Battery Wiring Question #19
and clothes you don't care about. You WILL lose them when everything blows up in your face.
/ Battery Wiring Question #20
I took the four 6V out of my lift and replaced with 2 big Optima 12V yellow tops 11 years ago. Still works perfect.
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2 Row Cultivator (A64047)
2 Row Cultivator...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
40' Shipping Container (A66285)
40' Shipping...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
