Battery tray repair
   / Battery tray repair #1
Twanger
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
I've had the battery acid take all of the paint off of the tray and start to rust. I would like to paint this before I put the Optima in. Could or should I use like a truck bed paint (herculiner), or should I use a regular spray paint?
   / Battery tray repair #2
Regular paint will work fine if that battery is of the sealed type. You could put down a sheet of rubber under it.
   / Battery tray repair #3
Clean that old try off goodbrush or wheel off loose paint, and clean with battery acid neutralizer in a can.. or make your own out of baking soday.. let it dry good.. them prime and paint it. I guess a rubberizing or epoxy paint would give you a greater amount of protection.
Soundguy
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2007 Mercedes-Benz S550 AWD Sedan (A51694)
2007 Mercedes-Benz...
