Battery tray repair
   / Battery tray repair #1
Twanger
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
I've had the battery acid take all of the paint off of the tray and start to rust. I would like to paint this before I put the Optima in. Could or should I use like a truck bed paint (herculiner), or should I use a regular spray paint?
   / Battery tray repair #2
Regular paint will work fine if that battery is of the sealed type. You could put down a sheet of rubber under it.
   / Battery tray repair #3
Clean that old try off goodbrush or wheel off loose paint, and clean with battery acid neutralizer in a can.. or make your own out of baking soday.. let it dry good.. them prime and paint it. I guess a rubberizing or epoxy paint would give you a greater amount of protection.
Soundguy
2014 JCB 930 (A50123)
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
FAKE (A52472)
FAKE (A52472)
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
