Battery tray repair
   / Battery tray repair #1
Twanger
Bronze Member
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
I've had the battery acid take all of the paint off of the tray and start to rust. I would like to paint this before I put the Optima in. Could or should I use like a truck bed paint (herculiner), or should I use a regular spray paint?
   / Battery tray repair #2
Regular paint will work fine if that battery is of the sealed type. You could put down a sheet of rubber under it.
   / Battery tray repair #3
Clean that old try off goodbrush or wheel off loose paint, and clean with battery acid neutralizer in a can.. or make your own out of baking soday.. let it dry good.. them prime and paint it. I guess a rubberizing or epoxy paint would give you a greater amount of protection.
Soundguy
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
