Battery Too Large?
/ Battery Too Large? #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
I just bought a used ATV with a Honda engine powered snowblower which I intend to sell. The previous owner changed the wiring so the clutch that engaged the augers was actuated by a separate external 12 volt riding mower / atv sized battery instead of from the ATV which was not included. Can I use my truck battery with jumper cables to test the clutch or am I risking damaging something with the larger battery?
Thanks for your input!
/ Battery Too Large? #3
12 V is 12 V, just dont do it with the alternator running.
/ Battery Too Large? #4
12 volts is 12 volts. Your load device determines how much current (amps) it draws. Just like plugging a night light into the same home outlet you'd plug a toaster oven into.
Use your truck battery.
Thanks, sounds good!
/ Battery Too Large? #6
The only possible drawback is if there is a short somewhere. The bigger battery won't deliver more voltage but if it can deliver more amperage it will. This means a short is more likely to melt some wires. The ability to deliver higher amperage will not damage a properly working clutch.
Eric
/ Battery Too Large? #7
Eric
The switch itself will be current limited, however it should have another fuse inline if it was wored properly.
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
Case 222 Garden Tractor (A66408)
Case 222 Garden...
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
LOOK! (A63111)
LOOK! (A63111)
Barrel (A64557)
Barrel (A64557)
