Battery Too Large?
/ Battery Too Large? #1
RidgeHiker
Gold Member
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
I just bought a used ATV with a Honda engine powered snowblower which I intend to sell. The previous owner changed the wiring so the clutch that engaged the augers was actuated by a separate external 12 volt riding mower / atv sized battery instead of from the ATV which was not included. Can I use my truck battery with jumper cables to test the clutch or am I risking damaging something with the larger battery?
Thanks for your input!
/ Battery Too Large? #3
12 V is 12 V, just dont do it with the alternator running.
/ Battery Too Large? #4
12 volts is 12 volts. Your load device determines how much current (amps) it draws. Just like plugging a night light into the same home outlet you'd plug a toaster oven into.
Use your truck battery.
Thanks, sounds good!
/ Battery Too Large? #6
The only possible drawback is if there is a short somewhere. The bigger battery won't deliver more voltage but if it can deliver more amperage it will. This means a short is more likely to melt some wires. The ability to deliver higher amperage will not damage a properly working clutch.
Eric
/ Battery Too Large? #7
Eric
The switch itself will be current limited, however it should have another fuse inline if it was wored properly.
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
3" Steel Posts (A66408)
3" Steel Posts...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
