battery recommendation for 4100
/ battery recommendation for 4100 #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
..believe the Mar '00 one is dead. I'll try to add a bit of distilled water, but it looks almost full as-is. Sooo.. off to buy a new one. I've read the Optima reviews. Impressive, but expensive. I will use my 4100 about 50-100 hours per year I'm guessing. Is there some other battery that might make more sense? Would a "cheap" lawn and garden battery suffice? Thanks much,
/ battery recommendation for 4100 #2
I replaced the battery on my 4400 last year with a John Deere Hibernator battery. Reasonably priced and seems to be plenty powerful. If you've got cold winters, don't go cheap on a battery.
/ battery recommendation for 4100 #3
The real problem with the factory battery's is they are prone to leak acid /forums/images/graemlins/crazy.gif Not many batterys out there that can give you a piece of mind like the Optima can...You cant believe how much damage acid can do in a short period of time...its not worth it to me to save a few dollars and potentially not solve the problem. I also have a 4100, and the factory battery leaked - so it was replaced with a yellow top optima 51 series...no regrets and no worries
Hope this helps
Ducati
/ battery recommendation for 4100 #4
Optimas are cheap. Be sure to add the cost of repairs to any lower priced battery. Nothing is a s cheap as an Optima. I bought mine from Remy battery, and it WAS cheaper than the local AutoZone (which only had the wrong one anyway...)
ok, I'll bite. remybatter.com
optima 51 or 51R $115
which is it 51 or 51R?
AutoZone has it for $140. I'll see if they match the remy $115 price. But AZ has the 51.
Remy is $115, s&h is $15, so net $130. Maybe AutoZone will match..
Looks like my Optima may be done. About 8-1/2 years. So I guess that's pretty good. Go Optima again? Or are their other comparable alternatives nowadays?
/ battery recommendation for 4100 #9
I've been getting that amount of time from the JD Strong Box batteries. They aren't cheap, but they were cheaper than the Optima's when I looked.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2012 Chevrolet 3500 HD (A64127)
2012 Chevrolet...
2022 EZ-GO ELITE...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
