Battery problems- ARRRRGGGGHHHH!!!!
/ Battery problems- ARRRRGGGGHHHH!!!! #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Well, yesterday, we got about 7" of snow during the day. I went out last night to plow the driveway and find the battery in the Massey doesn't have enough poop to start it up.
After trying to assist the battery with my portable battery pack, I gave up and pulled the battery with the intent of getting a new battery at noon today. When I pulled the battery, I found that it had an Interstate Batteries sticker on the side, but it said Yusua on the case. I also noticed that the top post terminals were about half size of posts on a car battery, maybe about 7/16" in diameter.
I called a couple of places and believed that O'Reilly's had what I needed. I went there and discovered that all they had was a group 51 car battery with large posts. A couple of phone calls to the local farm supply stores came up empty as well. So, I drove across town and went to the Interstate Batteries store and took the old battery inside.
Now----You know its a bad day when the clerk at the Interstate store takes one look at a battery with an Interstate sticker on it and says, "Wow, I ain't never seen ANYTHING like this before...." He picked up the phone and called who-knows-where and chatted for a bit and then hung up. He told me they could special order one, but it would take TEN DAYS and the coust would be about $81 + shipping.
Doing some quick math, with the special order piece being $30+ more then the group 51 car battery, I figured I maight be able to swap out the cables on the tractor for regular car cables and still come out ahead. So I went home after work, pulled the cables (amazingly easy, actually) and took them back to O'Reilly's to get new cables and a battery. Total cost w/ tax of $64.00. I took my loot home, installed the new cables, put in the new battery, crossed my fingers, turned the key and the beast roared to life quicker then it ever has since I've owned it. (Did I mention it was about 15 degrees at that point?) Finally got out about 9:30 and did my first snow plowing.
Do all Japaneese CUT's come with these cheesy batteries??
/ Battery problems- ARRRRGGGGHHHH!!!! #2
The day before the storm was to hit, my neighbor was trying to get his tractor started and the battery was stone cold dead. The tractor is an import from China and I didn't recognize the brand name, so I can't give you that information. It was something "King". The battery was buried down deep in the front of the tractor in front of and below the radiator. It didn't have battery terminal posts like most batteries, but had skinny 1" square by 1/4" thick terminals that the starter wire was bolted to. I looked at it and suggested that he get a standard automobile battery..... group 27 looked like it would fit and some new cables. Don't know what he finally decided, but, I have a feeling that he also ran into the same problem of cost and availability. I have yet to look at the battery in my Kubota BX-22, but I probably should..... If it is one of those @#$%#$& type batteries, then I will be getting the correct size cables to replace the originals when the time comes for a new battery.
I actually saw several bateries with the square terminals. Those are basically a motorcycle battery.
/ Battery problems- ARRRRGGGGHHHH!!!! #4
Boy, if I could find a new tractor battery around here for my Kubota M8950 for $81, I'd kiss the salesperson.
A new battery from my Kubota Dealer for my tractor is <font color="red">$493.31</font>.
Sam's Club down in Florida carries a battery that will fit mine, however, none up by me do. My parents are coming up in February for a visit. I'm having them pick one up for me and bring it up here. Sam's Club cost: $75
/ Battery problems- ARRRRGGGGHHHH!!!! #5
The battery in the Kubota L4310 was still the original and was getting weak. I was happy to see that it was a standard size, group 24 battery. $40 at WalMart. Took 10 minutes to change.
Rich
/ Battery problems- ARRRRGGGGHHHH!!!! #6
$493.31.....???? Nice profit for the dealer. Does anyone know why I can buy a huge Delco with a 7 year warranty for my Oldsmobile for $72 and tax, but a little Champion ATV battery (from TSC) costs almost $60 and has only a 6 month warranty and lasts maybe two years? I have found Walmart and Sam's club to be an excellent source of replacement batteries for many vehicles. Just wish they had a better selection.
/ Battery problems- ARRRRGGGGHHHH!!!! #7
Did you check the water level? If the water is low in just one cell, the tractor will not start when the weather is bad.
/ Battery problems- ARRRRGGGGHHHH!!!! #8
You guys that only need a new battery and a set of cables should thank your lucky stars that you don't have the same problem as the folks that own New Holland tractors. The battery on the NH and also a few others spews acid all over the tractor and the fan helps by moving it around a bit. At 50 hours or so I had to neutralize, clean, repaint, and get a new sealed Optima battery. Now that is a real pain in the a-- for a brand new rig. /forums/images/graemlins/frown.gif Optima batteries aren't cheap either mine was $140.00
/ Battery problems- ARRRRGGGGHHHH!!!! #9
I'm glad that my NH was a bit older.. a 1997 model, and had a large looking auto style battery.. though i'm sure it was oem.
When It dies earlier this year, I put in a wall-mart battery. I think I use d the midgrade.. 39 + tax.. etc.
Soundguy
/ Battery problems- ARRRRGGGGHHHH!!!! #10
I'm still waiting for New Holland to decide how they are going to handle my problem. Got a call from corporate in Canada and they are doing a bit of investigating into the matter. All i'm asking for is the cost of the battery, I ate the labor. I don't think thats asking too much for what I paid for the tractor do you? /forums/images/graemlins/tongue.gif
/ Battery problems- ARRRRGGGGHHHH!!!! #11
My Case 580 C had 2 huge 6 volt batteries in series. They were old and barely turned the engine over when it was cold. I went to Wall Mart & picked up a 12 volt battery with lots of cranking amps and that also fit my car. I made an 'adaptor' out of 2x4s and installed the battery. Worked like a charm.
The good news was, besides costing very little and being off the shelf, the battery came with a good guarantee (not that I ever needed it). 'Industrial' batteries usually don't have any, and cost much more, are hard to find, and so on.
The thing to remember is 12 volts is 12 volts, 400 amps is 400 amps. Wether it comes out of a few hundred D-cells or lead acid, the motor doesn't know the difference.
/ Battery problems- ARRRRGGGGHHHH!!!! #12
The hard part is finding a battery to fit. My battery is about 6" wide and 18" long with the two terminals on the short side.
| + Positive
| - Negative
Also, my tractor has a 96HP engine so I need a battery with about 900 CCA.
/ Battery problems- ARRRRGGGGHHHH!!!! #13
JDgreen227:
The ATV battery has a much rougher service life than a car battery. Vibration and bouncing are very hard on batteries.
Egon
/ Battery problems- ARRRRGGGGHHHH!!!! #14
Egon you can mount an Optima battery on its side and it won't leak. Thats rough service!
Dave why not buy a convention battery and lengthen the battery cable. They aren's a lot of money. I had a welding supply house make one up for me special for my last rig.
/ Battery problems- ARRRRGGGGHHHH!!!! #15
Rough service means lots of vibration and hard knocks.
Egon
/ Battery problems- ARRRRGGGGHHHH!!!! #16
Egon I think it qualifies but I may be wrong:
Inside this unusual battery is a six-pack of SPIRALCELL TECHNOLOGY®. Traditional batteries have a stack of thick lead plates surrounded by acid. But OPTIMA® batteries feature two thin lead plates wound into a tight spiral cell, with an absorbent glass-mat in between to hold the electrolyte solution.This unique design allows for more power and increased energy, resulting in quick, reliable starts. OPTIMA batteries are the first and only batteries to feature SPIRALCELL TECHNOLOGY.
It'll last up to 2 times longer than other batteries.
It can sit unused 3 times longer than other batteries.
It is over 15 times more resistant to vibration than other batteries.
It's nonspillable and can mount in almost any position.
It provides constant performance quality keeping your battery running at the same level even as it's being discharged.
It provides more power in the inital 1, 3, 5, and 10 seconds of the vehicle starting process than comparably rated conventional lead acid batteries.
OPTIMA Batteries are built to take a beating.
The OPTIMA Red Top Starting Battery will perform extremely well, often providing up to two to three times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice.
/ Battery problems- ARRRRGGGGHHHH!!!! #17
Pine ridge:
I sure wouldn't mind the new spiral wrapped batteries in all my stuff. They are probably the best on the market.
Egon
/ Battery problems- ARRRRGGGGHHHH!!!! #18
Egon I have no past experience with Optima as I only just bought one myself a month ago. However if they live up to their claims then they are worth the extra money that they initially cost. They do appear to be a superior battery, and I have not had any acid problems since I installed it. Time will tell.
/ Battery problems- ARRRRGGGGHHHH!!!! #19
I've used red and yellow top. All the Medic/ambulance around here use dual yellow tops(they have a major draw with lights, ect). My BIL has them in his Jeep. His are about 8 years old, and still winch fine.
/ Battery problems- ARRRRGGGGHHHH!!!! #20
Harley and some aftermaket suppliers offer gel cell batteries now. We have them in our FXRS's. Before, even a good battery only lasted a year, maybe two if lucky. Thier clean too. No overflow to put acid on the chrome...
2014 BMW X1 S Drive 28I SUV (A61569)
2014 BMW X1 S...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
