BATTERY ON FIRE!!!
/ BATTERY ON FIRE!!! #1
futuorganics
This is the person w/the alternator and battery problem.
1st...Thanks for the info on how to locate the positive and neg terminals...still however, when I switch the cables, I got a lot of smoke from the alternator and I got a lot of sparking from the terminal cables coming off my tractor(2210D). In fact, the positive term. cable turned bright red after running the tractor for about 3 minutes.
What the **** is goin on /forums/images/graemlins/confused.gif
2nd...I am pretty sure I burnt out the diodes on the alternator. I am on my way to autozone to check out the 72' Nissan alternator /forums/images/graemlins/wink.gif
Do I have to make any structural adjustments to this alternator for it to fit? If so, what are they?...Or am I better off just buying a Yanmar alternator for my 2210D?
The price difference is a $120 /forums/images/graemlins/frown.gif.So I guess you know why I'm leanin towards the Nissan.
3rd...Is there a specific series of #'s I should look for when purchasing a battery for the tractor?
I assume that any old car battery would do. But I am questioning any assumptions now... I don't wan't nothing else to catch on fire /forums/images/graemlins/smirk.gif
4th...Assuming all that I need is to change the alternator. What should I keep in mind while doing so?
Thanks all
/ BATTERY ON FIRE!!! #2
#1 It sounds like to me you may have a short somewhere.I would look for a short before I replaced any parts to keep from destroying another good part .I would think any 12 volt car battery should work fine.Have you checked the cost of having the alt. rebuilt vs autozone?
/ BATTERY ON FIRE!!! #3
</font><font color="blue" class="small">( Re: BATTERY ON FIRE!!! In fact, the positive term. cable turned bright red after running the tractor for about 3 minutes. - futuorganics)</font>
Stop and get someone to work with you who has experience replacing the battery and searching for a short - a friend or neighbor, or pay a shop.
Batteries are inherently dangerous and what you are experiencing here could lead to disaster if it explodes while you are nearby.
/ BATTERY ON FIRE!!! #4
By starting a new thread with every post, you are making it extremely difficult to assist; however, you most likely now have a direct short to ground in your alternator, and no, a bad cable does not cause a short, only an "open". I repeat the suggestion to take the alternator and regulator, (follow the wires from the alternator to a little black box, about 2 1/2x3" either on the firewall or under the dash), to the parts store for testing.
/ BATTERY ON FIRE!!! #5
<font color="blue"> This is the person w/the alternator and battery problem. </font>
If you would keep this same topic going within your original thread -- you wouldn't have to explain this.
/ BATTERY ON FIRE!!! #6
Be sure to check the positive cable and make sure that it has not worn through and shorted to ground, that could cause all the problems you've been having. If it got hot enough to turn red, I would replace it just to be on the safe side, you can take the old one to any parts store and they should be able to match it.
/ BATTERY ON FIRE!!! #7
In all honesty it sounds like you need help. An experienced mechanic would have stood back and said "what's wrong?" Instead you hooked things up and actually ran the tractor. That is wrong on so many levels that you really need to stand back and address your abilities. Sorry to be so brutal, but it's the truth. /forums/images/graemlins/cool.gif ?
your honesty is appreciated however, i can't afford a serious mechanic. In many ways that is the value of this discussion group. What I have managed to do is sit around the parts store and ask alot of good questions from mecahnics coming in and out. Again thanks for your honesty.
/ BATTERY ON FIRE!!! #9
Dude so far you have cost yourself more than paying a mechanic would cost... Replacing a battery is one of the most basic things a person can do to a car or a tractor. Replacing a battery also can be very dangerous. You are lucky your battery has not exploded yet. If it does exploded it will send battery acid all around and could blind or scar you or someone else or an animal for life.. You need someone with some knowledge and sense to assist you. Do you have any friends that know a little about cars etc....?
Good luck
/ BATTERY ON FIRE!!! #10
Where are you located ? Maybe someone on this board lives close by and could come by to assist you. /forums/images/graemlins/laugh.gif
/ BATTERY ON FIRE!!! #12
Based on your abilities, I would pony up for the original alternator. Installing a different alternator is not an easy thing to do. You will need to fabricate a bracket to mount and tension it. You will need to wire the alternator. You will need to route a belt to it. Spend the money for a replacement oe alternator. Before you disconnect it, draw a picture of the wires. Note both the wire color and the terminal type. Consider using different types of tape to mark the connections. Now go to the battery. Trace the wire down to the connection. It will either go to the starter or the frame. Mark the hot wire with a piece of red electrical tape. Now trace it again. Do it a third time to make sure you have things right.
Does anybody know if this tractor has a fuseable link he may have blown?
/ BATTERY ON FIRE!!! #13
I 'd agree with the OEM replacement, unless you could find an alternator that fit the factory brackets.
That's what i did onmy 1700.. the mom-n-pop alternator shop found me one that fit the same as the original, and I wired it in using an old chrysler style VR.. charged great.
Soundguy
Thanks,
the new alternator is identical to the old one. Both were made by Hitachi. I ordered a voltage regulator as well. Once I look at it I will determine whether or not I should use it or not. BE intouch soon.
Oh, the battery didn't really catch on fire. The positive head on the terminal cable turned bright red however. I should have said a potential fire. I cut it off immediately. I assume from the discussion however that it might be a short with the voltage regulator. I plan to talk to a mechanic. Thanks though for the info. Any other suggestions u may have will be useful.
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
