Battery Longevity
   / Battery Longevity #111
I own several "battery maintainers" of various brands. They all work fine. All are "smart" in that they shut off when a "full charge" is achieved. What is different about them is that each has a different definition of a "full charge". One of the Battery Tender units has different settings for different styles of batteries, which I assume changes the definition of a "full charge". Being a creature of habit, I still refer to them as "trickle chargers". I have found that if you do that on this forum you will get chastised:)
I like being able to select between AGM and flooded batteries to optimize the charge voltage. I have one Optima maintainer and it has 2 AGM selections, one for start batteries and one for deep cycle batteries. So there is even a difference there. That charger can figure out what kind of battery it is attached to on its own.
   / Battery Longevity #112
I too visited China often. Established a branch of our company in Shanghai. Used to buy Rolex watches and pearls in the local market. Over the years, one of the local merchants even grew to know me by my first name. Still have the Rolex watches....yes, they keep accurate time once a day!
The pearls however are still valued by many of my wife's fiends who received them as Christmas gifts.
Today, I would never return to China. I also avoid buying anything made there.
I just gave a beautiful pearl necklace to my granddaughter for her December Georgia Tech graduation.
I have a REALLY valuable strand of pearls to give to somebody...someday...maybe...., if not,..... my son will dispense them through my will.
   / Battery Longevity #113
So true!
Especially the "chastised" part!
   / Battery Longevity #114
I would retire that antique and put it in the local museum.
NO it is like gold...
All of my other chargers require some voltage to start charging... in a pinch I have paralleled two 12 volts to trick the smart chargers.
But with the old guy it just puts out...
I did loose my 6 volt 80 amp max Baldor... loaned it to a friend and the mesh back plate somehow dented and stopped the fan and it melted down... it also did 8 volts which is rather rare...
Not saying I have never broken anything... but it does seem others are more apt to be careless...
I broke a borrowed harbor freight tile saw and went right out and bought a new one to return and kept the old one I was able to repair.
The friendship is more important plus personal responsibility...
I keep looking on Craigslist for an old 1950's garage charger with 6, 8 and 12 volts...
   / Battery Longevity #115
Imagine that, an item made on the other side of the planet costs more by the time that it gets to us.
   / Battery Longevity #116
Okay all, I've got a question regarding this subject. I've got a Champion generator that's 6 years old. Last year the ignition switch failed, I replaced it and no future problems. This year when I tried to crank it up -- the switch said rrrrrrrrrrrrr... and nothing else. I thought switch again and bought a few spare replacements. But it puzzled me and so I tried just hooking up a spare lawnmower battery I have in the garage (on a trickle charger); and whroom it cranked over like no problem. So it's a faulty battery....or so I "assume".
I admit the first 4 years of the original generator battery life were "not" on a trickle charger for the down periods. Would that be enough to cause it to die?
For the last two years it's been on a Battery-Minder 1500 (which charges, maintains, and de-sulphates), as are all of my other batteries. I've had no problems with any of those other batteries for 3 years - although they are - in fact - newer batteries than what's in the generator.
Anyway, my generator battery shows 13.6 volts, which says it's fully charged, yet it won't crank the genny over. I put my [Harbor Freight] load charger on it and it failed. Now, I don't know enough about a load charger to know for sure how it works. I did hook up to the spare battery I used to check the switch on the genny and it did show that battery to be good.
My question is -- can a fully charged battery - in fact - be a dead battery? I'm thinking it is and a mere 30$ or 40$ to replace it isn't an ending. Just, is my interpolation of how a load charger works correct or faulty? I'm guessing here now and would appreciate some advice on my thought patterns. Thanks to all. Greg
   / Battery Longevity #117
You are very fortunate that your battery has lasted as long as it has.
Those small lawn tractor type batteries are almost all just cheap junk.
I figure they are good for two, or max, 3 years.
Don't waste your time fretting over it.
Buy a new (cheap junk) battery....you NEED it!
   / Battery Longevity #118
Thanks fried1765, That's what I was thinking but got puzzled by use of my load tester and the multimeter. I kind of figured the battery was junk. Do you know of any stronger - same sized - batteries that work any better? Since I've got to replace, rather do it with something better if it's out there.
   / Battery Longevity #119
I have read that the small size Yuasa batteries are good, but have no personal experience.
   / Battery Longevity #120
I too don't know what your HF Load Charger does but put voltmeter on battery while trying to start your generator. Rule of thumb says less than 9 volts while starting is time to replace battery. Am guessing that because you get no starter action the battery may be close to zero volts.
And yes, battery voltage is a poor indicator of the battery's capacity. There is a low energy capacitive charge on battery after charging which is why it is recommended to test car battery voltage only after 30 seconds or so of headlight with engine off. Let the headlights burn off the capacitive charge.
ENCLOSED DRIVING SIMULATOR TRAILER (A58216)
ENCLOSED DRIVING...
TORO MBTX-2500S STAND ON MUD BUGGY (A52709)
TORO MBTX-2500S...
2018 RAM 2500 (A58214)
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
