Battery Light B2910
   / Battery Light B2910 #1
ChrisC
The battery light comes on when I start the tractor. As I crank up the RPMs, it begins to dim and goes out at around 2,000 RPM.
I tightened the belt, visually inspected the wiring, removed and cleaned a few connections. All looks good to my untrained eye. What are my next steps?
Thanks,
Chris
   / Battery Light B2910 #2
It should go out a little above idle. Try monitoring the generator output voltage as various engine speeds. It sounds like the brushes may be worn out. Replacing them is generally a simple process. Another option is a defective voltage regulator but I'd start with the brushes.
   / Battery Light B2910 #3
Assuming that your battery is the standard 12V wet cell, a proper working alternator or generator should be putting about 14.5 volts into the battery, measured at the battery, with the engine running at a fast idle or just above idle.
Richard
Checked with a multimeter. Battery reads around 12v. With tractor running, it’s basically the same reading.
When I rev up the engine to 2,000 RPM the light goes out, but the reading at the battery is the same.
Next steps? Is it most likely the alternator?
Thanks - Where would I monitor the generator output?
   / Battery Light B2910 #8
As someone suggested, you could have a bad battery. Take it out and go to a auto parts place and have them check it.
   / Battery Light B2910 #9
It's probably the voltage regulator. There are a few threads on here about it specifically. If you buy one, I'd suggest just getting the genuine Kubota part. I tried the cheaper version via Amazon and even though it looked IDENTICAL, it only lasted a few weeks. Once I replaced with OEM, it's been good now for several years.
Mine actually went up in smoke and I was lucky that it didn't catch fire. Do you notice any smell, like burning rubber? The voltage regulator is behind the dash panel.
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
WB Mower (A50120)
WB Mower (A50120)
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
