Battery life expectancy - Manufactured 2014 LS G3038?
   / Battery life expectancy - Manufactured 2014 LS G3038? #11
Mine is a 2015 MY; still on the original battery. Never put a tender on it, and it started yesterday at 0°. Maybe a little slower to turn over than in the summer, but it isn't showing any signs of dying yet. Once it does, I will probably replace it with an Interstate as I have had good luck with them over the years.
   / Battery life expectancy - Manufactured 2014 LS G3038? #12
I swap out my car/truck batteries every 5 years, I don't want to get stranded.... I wait until the tractor batteries die of old age, never more than 7 years. Everything I own is in a garage that I can easily heat if needed. If the tractor battery gives up the ghost I will turn on the heat, charge/jump the battery and get a replacement asap.
   / Battery life expectancy - Manufactured 2014 LS G3038? #13
Well I went to my small town automotive parts dealer and found a 51R sealed battery that met the dimesions and surpassed the CCA for less than 80 bucks. Since then I happened to notice the battery in my 2009 Honda Element and it too is runing the 51R battery. Interesting.
   / Battery life expectancy - Manufactured 2014 LS G3038? #14
My tractor batteries last on the average ten years. At least, that's when I replace them. I DO NOT want to get caught in the winter with a dead battery.
   / Battery life expectancy - Manufactured 2014 LS G3038? #15
I get about 10 years on my tractors but I'm **** about keeping them on a tender even in the summer.
Wierd timing for this post, daughter and I went to HD yesterday, shut her rig off, a 2009 Journey, came out battery was deader than a nit, 2-1/2 years old, had to get a boost from CAA to get home and get a new one. Stupid POS, the battery is ahead of the left front wheel, you have to remove the wheel and the fender liner to change it, not much bigger than a motorcycle battery.............Mike
   / Battery life expectancy - Manufactured 2014 LS G3038? #16
I only got 2 years out of my XG3025 because my grandchildren had a habit of playing on it and leaving the lights on and draining it completely. The cheap wal mart battery has been in it for 3 years with no problems.
   / Battery life expectancy - Manufactured 2014 LS G3038? #17
My original tractor battery lasted 11 years. My replacement battery is nearing 10 years and still going strong.
Neither have ever had a battery tender on them.
   / Battery life expectancy - Manufactured 2014 LS G3038? #18
I bought my R4047H in early 2012 and it still has the original battery. It stays on a battery tender in an unheated garage.
   / Battery life expectancy - Manufactured 2014 LS G3038? #19
Bought my R4041H in October 2013 , still original battery kept in unheated garage. I put a battery tender on it every once in a while but it doesn't take long to bring it up to full charge. The battery feels as strong as ever.
   / Battery life expectancy - Manufactured 2014 LS G3038? #20
If you don’t already have a desulfating charger you should consider getting one. This is the one I have bought from my local Honda dealer.
2012 Pinehill Gooseneck Trailer (A51572)
2012 Pinehill...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
1999 International 4700 Dump Truck, VIN # 1HTSCAAN3XH660516 (A51572)
1999 International...
